1995 Dodge Dakota Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LOOKING FOR A 95 DODGE DAKOTA 2.5 UNDER THE DASH FUSE BOX DIAGRAM. I NEED TO KNOW WHICH FUSE GOES WHERE!
Patrick Miller
Level 2:
Sergeant:
  • Expert 154 Answers
  • Posted on Apr 04, 2009
Patrick Miller
Expert
Level 2:
Sergeant:
Answers
154
Questions
Helped
55509
Points
546
Look in the owners manual (look up fuses in the index) or go to your local library and they should have a manual or they should have an "AllData" system.
I just don't understand why everyone wants to know where the fuses go? If you're redesigning the electrical system then great, you also need a schematics. But if you're trying to troubleshoot something that doesn't work, there may be more fuses then what the fuse panel calls out. For example: Radio - one fuse is shown for the radio when in fact there are three that affect it's operation.
This is the best way to do it. Buy a 12 volt test light. Turn on the ignition and probe both sides of the fuse. Both sides light up, it is good. If neither side lights, connect your light to the positive termanel and probe the fuse again, if both sides light up, it is controlling a ground circuit and is good. And check all the fuses in both the fuse panel under the dash and under the hood. That will tell you if you have any blown fuses. If you need help troubleshooting a particular system then let me know, but do the fuse check first.
I hope this works for you and have a nice day!
I need a diagram for the interior fuse box on a 95 dodge dakota pickup
BBB INDUSTRY'S ONLINE UNDER TECHNICAL HAS Wiring and fuse/relay diagrams .
2answers
Need a fuse diagram for a 2005 Dodge Dakota SLT Quad Cab 4x4
Look underneath the cover for the main fuse box under the hood. It should have a diagram for all the main fuses along with the sizes and the relays.
3answers
Fuse box diagram for 2001 Dodge Dakota
Find a fuse diagram printed on the back of your fuse box cover, or follow this link to know the placement of each fuse in your car: https://knigaproavto.ru/shemy/en/dodge/dakota/766-2002-2004-dodge-dakota-fuse-box-diagram.html
I need to know which fuse to put in my 1992 dodge dakota pickup and which place to put it.
Which Fuse are you needing to Change? The Fuse Box is Located Under Your Dash Board on The Drivers Side. If you still have the Fuse Box Cover it will have a Diagram of what fuse goes where and for what each fuse is Used For. From: WYOCWBOY
3answers
Need to replace the fuse for the cigarette lighter
I dont happen to have one of those diagrams, but if you pull the fuses one by one and replace the burnt ones you should be able to 1.) Identify what item is on what circuit (for the most part) and 2.) solve your original problem with your cigarette lighter. Hope this gives you some direction. Thanks for Using FixYa!
Sincerely,
JC
1995 Dodge Dakota 4cyl 2.5
type in zzzz fuse box diagram on google. com
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
