Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Color yellow background no blue
  • ohbiamshort Dec 26, 2007
    My tv has a blue shady drop on the top and the sides of the screen and in the middle i see double with a red shade. Almost like looking at a 3-D movie without the glasses. Help!
  • 87 Answers
Probably contaminated fluid in blue crt. Have experinced Samsung/Akai shop change and re-align. Probably cost $250-300
Posted on Dec 20, 2007
SOURCE:
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 | Computers & Internet
Weird colors when dvd is played
i think the video out cable is not inserted in the proper jack try out other video out jacks they are yellow in color.
pls vote me if you find this helpful.
Mar 25, 2010 | Philips Televison & Video
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Background of any game is all one color such as blue or yellow.
To gmarshall, I had the exact same problem. no video, no audio, no red lights. The problem is that over time, the A/V input sometimes melts. I had to send mine in to microsoft. But before you do, they will tell you to buy a new A/V cable. Dont. Just bring a friend's cable over. This is just to make sure that the problem is with the console. If it still doesent work, you will have to send it in. But if you have had the 360 for more than a year, they will charge you $100. Sorry for the bad news.
Jun 30, 2008 | Microsoft Xbox 360 Console
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Scanning barcodes with colored background
unfortunately it appears that you do not have sufficient Contrast for your barcodes, this will make scanning them difficult, that with the added issues of wear & fading makes the use of barcoded passcards difficult. it's probably better to use RFID or Magstripe cards for this application
Sep 05, 2007 | HHP Imageteam 3800 Handheld
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
