Question about Olympus WS-100 Digital Voice Recorder
Unlocking Locked Digital Recorder
I have a teacher that has the WS-100 and has had it locked for a long time. She has tried tech support and the users manual with not avail. Any help is appreciated! Thanks! Than
  • 1 more comment
  • ThanITRT Aug 22, 2007
    All the files are locked. When I hit the menu button it scrolls through the letters A through E on the top of the screen. Yes, I can play back the files, but I can't edit or erase any of those files from the recorder. Nor am I able to get to a spot in the menu that will show me the On Off function as you show in the picture above.
  • Katlin Jan 18, 2008
    I cannot unlock the files on the WS-100. I have tried to unlock the same way. Files are firmly locked. Any suggestions?
  • Anonymous Feb 20, 2008
    I have the same exact problem. All my files are locked for some reason and I can play them but cannot record new ones or erase the ones i have. I pressed the menu botton and got to the option lock but none of the buttons will allow me to get it to " lock- off" button. After struggling with it for hours, I decided the format and that fixed the problem. I just hope it does not happen again.
Very frustrating for my technophobe journalist wife but changing the format is the solution and it's not as easy as it sounds. To avoid 'struggling for hours', olympus should have included something like the following instructions: access the options via the menu button (pressing it for a few seconds) then choose format with ff or rew but wait for 'yes' to appear and not just for 'no' to dissappear. Then  press play and wait for 'are you sure' to cross the screen and  choose 'yes' again and wait again for the 'done' message. Eureka, you can start recording again.  Fiddly enough, so without proper instructions...!  Hope this helps.
Posted on Mar 20, 2008
I had the same problem I some how locked my recorder, I just figured out how unlock it.
1. Go to menu and then select the "format" category.
2. Select yes to format.
3. Mine asked me if I was sure that I wanted to format this and I said Yes again.
4. It formatted for a few seconds and then it returned mine to normal.
Hope this helps all.
Posted on Sep 25, 2008
I have the same problem; however I cannot even play the file I have. I cannot play, erase or record. I do not have a picture to post. My display looks different from the picture posted by informatica. The erase lock indicator is present, and I can scroll through to lock using FF or REV. The difference is in the little box above lock where that picture shows On - mine shows 00. When I press play in hopes of getting an on of an off to appear only 00 shows up. I tried to press FF after pressing play to see if that would make an on / off appear, but all it did was send me to MIC (the next option). I tried just about everything after that to get anything to display other than 00. My olympus will now show an on or an off unfortunately =(.
A few minutes ago I attempted to do the format method posted by frenchfrank, and that worked luckily. I lost my whole lecture unfortunately; however, I am able to continue using the Olympus WS-100. I decided to post this in hopes that a solution might come out of it for another person with the same problem. I hope this problem does not repeat itself.
Other than this occurrence, this Olympus ws-100 has been wonderful! I can place it on a desk in the back of the classroom and record the instructor clearly lecturing in the front of the room.
Posted on Mar 24, 2008
  • mistyrainn Mar 24, 2008
    I have the same problem; however I cannot even play the file I have. I cannot play, erase or record. I do not have a picture to post. My display looks different from the picture posted by informatica. The erase lock indicator is present, and I can scroll through to lock using FF or REV. The difference is in the little box above lock where that picture shows On - mine shows 00. When I press play in hopes of getting an on of an off to appear only 00 shows up. I tried to press FF after pressing play to see if that would make an on / off appear, but all it did was send me to MIC (the next option). I tried just about everything after that to get anything to display other than 00. My olympus will NOT show an on or an off unfortunately =(.
    President:
  • 1,114 Answers
Hi Than, tell us a little more about the exact message you see on the player, is it like the attached picture? Does the player come on OK and do any other functions work like playing back recordings? Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
  • Greg Cann
    Greg Cann Aug 22, 2007
    You need to press the menu button for a second or longer to access the options. Have you tried both FF & REW keys to see if you scroll to the lock function? Another option if you can get to the menu is to format the unit, this will erase all files.
    Lastly can you connect it to a PC & delete the files? Do not try formatting it on a PC as this will delete the units operating system & it will be useless!
  • Greg Cann
    Hey great you got it working?!
    Which fix worked for you - inquiring minds need to know!
    Best regards,
    Informatica.
Thank you
French frank, perfect solution ro the locked recorder.
M
Posted on Sep 09, 2008
SOURCE:
Sd card is locked ,tried two different cards. how do I unlock sd cards
There is a small slider on the thin side of the card for lock/unlocking.If you have tried two new cards then the camera probably has a fault with it's detection sensor.That's a job for a camera tech.
Sep 25, 2011 | Vivitar DVR 508HD Digital Video Recorder
All the files in voice recorder ( model is olympus digital voice recorder WS -300M) were locked and everytime I tried to transfer or open them, I can't, the computer says that the files are corrupted. How...
Yes, the files are likely corrupted. You can try a file recovery program such as PC Inspector Smart Recovery. Search snapfiles.com for a free download.
Apr 26, 2011 | Olympus WS-311M Digital Voice Recorder
My olympus digital recorder ws 100 is locked please help
The lock is to prevent accidental erasure of files....if you have lost your operators manual go to www.olympusamerica.com you will find manuals under "support."
Sep 07, 2010 | Olympus WS-100 Digital Voice Recorder
Olympus Ws-100 voice recorder locked
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1170
Here is the link to the Olympus website where you can download the manual. In it there are steps to format the device which should clear all of the data and you should be able to start recording on it again.
Mar 16, 2009 | Olympus WS-100 Digital Voice Recorder
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Can't unlock my locked digital recorder
format the recorder through the menu and this will erase all the files
Sep 25, 2008 | Olympus WS-100 Digital Voice Recorder
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus ws-100
what do you mean locked? there is an hold button that slides and then you can't use any buttons, try to slide it the other way to unlock it.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100
do you mean lock?
you can just lock the buttons by sliding the hold button.
Aug 17, 2007 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
963 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
