Canon PIXMA MP600 all-In-One InkJet Printer Logo
Posted on Mar 25, 2009
CHANGED INK, WON'T PRINT.
I changed a ink cartridge, now the copy function won't print on page and if I print a document from computer, print is blank, but will print directly onto cd??? I have done maintenance on machine with cleaning, did print colours, tried printing document, still blank?
CdRon
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Mar 25, 2009
CdRon
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
2419
Points
36
Try to reinstall software restart pc when it asks if the cartridge is new say yes
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
2helpful
Printer won't scan because it's out of ink
Unfortunately, all-in-one printers are printers/copiers. The scan to a computer function is a secondary function and the unit has interlocks to keep it from being damaged when the ink is out. There is a way to print with only one ink cartridge in place but this only allows print jobs from the computer. The copy and scan functions are locked. For details, see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673672&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3742086#N2374 . See the section on Ink Level Indicator (!) and the bottom notch of the indicator blink fast and the Workaround: Print in ink-backup mode
You need a stand-alone scanner if you routinely want to scan to your computer without a printer ink level OK status report.
I wish that I had better news for you.
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
5helpful
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
1helpful
2answers
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
old marine
old marine
ZJ Limited
ZJ Limited
