Question about Dell E153FP 15" LCD Monitor
How to open dell wh 320 monitor for repairs
Dear sir I have never opened the casing of dell tft monitor model wh 320. explain in detail with diagram if possible for circuit repairs thanks samaki
  • 46 Answers
Re: how to open dell wh 320 monitor for repairs
Check out this link for videos on how to open dell LCD monitors.
Posted on Jun 21, 2008
0 characters
3 Points
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
I keep getting an icon, directly in the center of my screen, that looks like a Master lock. Sometimes it's "locked" other times it's "open". Then a series of screen settings opens up....
You have a problem with the buttons on your monitor. The symptoms you describe indicates that the problem is with the menu button acting like it is being constantly pressed. It often caused by debris getting into the button. To troubleshoot, you will need to open the case of the monitor to clean/repair the problem. To do that, you will need a putty knife and seperate the two bezel from the back panel. To help you explain how to open the monitor look at this video Hope this helps you.
Jan 21, 2011 | Dell E171FPb 17" TFT LCD Flat Panel...
Not power up after electric went off
Try replugging everything and turning your powerstrip on and off. If that doesn't work then it probably shorted out.
Feb 28, 2010 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
How do i open a Dell TFT monitor model 1505?
poginga, Try visit to YOUTUBE for video clips "lcd monitor disassembly" and or "lcd monitor repair" to get basic idea of how to !!! DO NOT USE SHARP BLADED INSTRUMENTS OR YOU WILL END UP IN THE LOCAL "ER" TRYING TO EXPLAIN THE BLOOD GUSHING OUT FROM YOUR BODY" 12fixlouie
Feb 22, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
Is there a way to open the monitor case to fix the backlight without using a hammer and chisel . . ? Dell Model #E153FPc
Yes the screens are held together by screws and clips. you need an electronics plastic opening tool to not damage them but they are repairable without having the damage them.
Feb 12, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Need to remove dell e193fpc flat panel covers to repair
First remove the stand. Then at the bottom of the monitor there are two small openings an inch or two from each edge. Starting there with WIDE flat blade screw driver (or a couple of them) it IS possible to pop the catches that hold the back of the case to the front. You have to go around the case very carefully popping each catch and preventing the areas you have opened from becoming re-latched. I found some wood popsicle sticks good for that.
If you search for "LCD Monitor Repair" you can find sites that have video's of several Dell models (but not this exact one) any that use the "pop open" case are pretty much similar.
One note after you get inside. The power supply board had the WORST solder job I have seen in a long time. The failure in the unit I repaired was due to open solder joints on the hi-voltage transformers taking out the power transistor's that drove them. It took me two months, but I found some replacement transistors on ebay and after resoldering many of the joints on the board it the monitor works fine.
I attribute part of the failure to the use of Lead free solder which is becoming common in all consumer electronics. It makes for brittle connections that fail easily and there is also the issue of tin whisker growth that will hit in a few years down the road.
Mar 09, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell monitor wh 320
Just done mine and the plastic case/frame is secured with clips all the way around.
Remove the stand/bracket screws
Place the panel on its top edge and look down on the underside join.
You will see two small notches where you can get a pen knife/lever in. Dont poke in too far especially where the buttons are.
Now lever the back off the front by leaning your knife/lever in the same direction as the screen front. Once you have the first clips free you can work all the way around in the same way taking care not to damage the plastic much.
I hope that helps someone else who is stuck like me at first and found this Q unanswered and eventually I decided I had nothing to loose lol.
Aug 22, 2007 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
451 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
