I got this gpx boombox at a thrift store for work.Insert cd and two red lines flash then an upside down U and a small o appear. I open the cd door and disk is not spinning.Fixable or not
SOURCE: Boombox won't play most CDs
Hi there , heres a simple case of the recording format on the cds , its likely that your daughter's cds are recorded on a computer in a format probably mp3 or higher speed thats not compartible with your boom box . The solution to this is to record your cds in Normal format , and they will surely play !
SOURCE: Emerson PD6810
Unfortanatly, this is why Emerson only warranties these for 90 days, but I have heard and recommend that you contact Emerson and tell them you did not think that their product would break down after a mear 90 days and a lot of times, they will send you a new one, if you bug them enough. There should be a contact number in the owners manual. If you do not have the owners manual, go to: http://www.emersonelectronics.ca/emerson/en/home/ There is a contact link there. By the way, the problem you are having is a bad spindle motor or the laser optics are bad. Have you tried to clean the small laser lens off yet with a cotton swap and some good 90% or better alcohol? Good Luck
SOURCE: Boombox radio plays but cd doesn't
First place to start is making sure that the lense is clean
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
SOURCE: Cd player on boombox not spinning properly.
Might be the laser but try lubbing the spindle motor 1st!
