Question about Jura Capresso Impressa X90 Espresso Machine
Stopped up The coffee does not come into the cup. It dumps the coffee into the grounds bin.
  • abelb Mar 15, 2008
    No coffee comes out of the coffee spout, it instead displays the message "FILL SYSTEM/PRESS STEAM". When you press the steam button hot water comes out of the steam nozzle, and dry ground coffee is deposited in the tray.
    The same thing happens when you attempt to rinse or clean the unit, instead of the water coming out the coffee spout as it's supposed to, the "FILL SYSTEM/PRESS STEAM" message comes on, and when the stem button is pressed the water comes out the steam nozzle instead.
  • Anonymous Mar 17, 2014
    Please help.
Http://www.cafecorporate.com.au/FAQS/ProblemsandMalfunctions/tabid/75/Default.aspx#_Coffee_in_grounds
In most cases it is a result of the brewing unit getting jammed.
Some of the most common problems are :
Split ‘O’ Ring on Brewing Unit
Faulty Coffee Brewing Unit
Twisted ‘O’ Ring on Brewing Unit
Beans In Decaff Chute
Split White Cog In Brewing Unit
Water Leak On Transformer
Faulty Encoder
Plug on logic board from encoder faulty
Faulty transformer
Workshop repairs required.
Posted on Mar 15, 2008
Machine grinds beans but dumps coffee in box cup
hi , sounds like the dump valve solenoid has failed or the valve on the base of the brewer has failed probably stuck,.which is the more likely culprit. let me know if you require more in depth help.
its not a problem that can be resolved by a novice.
Mar 30, 2014 | Franke Saphira Espresso & Coffee Maker
Kcup is dumping all the grounds into the machine and coffee cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 15, 2011 | Keurig B60 Coffee Maker
My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Jan 30, 2010 | Cuisinart (CCCCUISINART) Grinder
Grounds dry, non-pressed and jettisoned to bin. Pre-ground function fine. Otherwise, no coffe.
The solution to this Saeco Incanto Deluxe problem was simply tweaking the Program Menu settings. After receipt of the unit, I immediately set all settings to STRONG. This move proved to be a major complication because the machine could not compress the load of grounds being dumped into the brew unit. I responded by setting ALL coffee settings in the Program Menu to MILD and now only use the Large Coffee SBS setting for regular coffee (the coffee is still robust and delicious).. The expresso SBS setting and those SBS settings further to the left I use only with the small cup button. If I want a double I just do it twice. The machine was protecting the drive shaft and brew unit from damage by stopping the press and jettisoning the grounds when I had the machine programmed the other way. I hope this helps other owners.
Jan 03, 2010 | Saeco INCANTO DELUXE Espresso Machine
When pushing button for a cup of coffee to be made - the beans are grinding and dumping in the box - however no water is coming thru to empty into my cup - the water is being dumped into the reservoir...
Hi
Dry grounds dumped.
There is a lever at the top of the door on the right side. Yours is actually inside the door on the machine. Pull the lever back 1 notch from the plus(+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it, or breaks the drive gears. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge.
Oct 24, 2009 | Saeco Magic De Luxe Espresso Machine
Mini brewer shuts off wont heat up wont make coffee Light goes off after cup is placed to catch coffee wont heat or make coffee
thow it on the ground and stom on it. if its not working now theres nothing you can do. Take it to the dump
Jun 28, 2009 | Keurig Ultra B50 1-Cup Coffee Maker
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
Jura Capresso Impressa X90 Espresso Machine Logo
485 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
