Question about Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF) (MDMZN5600CF)
Connection speed I have a laptop with Vista Home Premium and a Zonet pcmcia V.92 modem card. I cannot see what the connection speed is. All that is being reported is the maximum connection speed of 115k. This is using the Vista standard V.92 pcmcia modem driver. I live in a rural area and my connection speed varies every time I dialup. It would be very useful to be able to see the speed that I am connected at. Thanks Lee
  • lee_ms Aug 22, 2007
    Thanks for the reply but the problem is that I can't see my connection speed at all.
    Under modem properties it shows my maximum port speed as 115200. When I connect to my ISP Vista shows 115.2 as my actual connection speed, every time I connect. This doesn't prevent me from accessing the internet but when I get a really poor connection it is better to hang up and retry.
    President:
  • 2,961 Answers
The usual maximum speed for a v92 dial up modem is around 48-52kbps, although sometimes the way windows calculates the speed can be different, showing higher speeds than is actually possible, hence the 115k that shows when connected. The only way you can get faster download speeds is to download the 'Onspeed' software which compresses pictures etc to enable twice the download speed.
Posted on Aug 22, 2007
SOURCE:
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
Toshiba 3010 Portage CT network connection options
The RJ11 jack is for connecting to a phone line, your laptop has a built-in phone modem.
You need a network card with a RJ45 jack, there are numerious PCMCIA network card available, there are also USB network devices that you can use. I suggest you use a PCMCIA network card, and leaves the USB port free for other uses.
May 13, 2009 | Toshiba Portege 3010CT Notebook
Modem for Dial up
it will not be compatible, the slot on the right side is an ExpresssCard Slot.
You might want to try a USB modem
http://www.zoom.com/products/dial_up_external_usb.html
Mar 21, 2009 | Dell Inspiron 6400 Notebook
MY USB HSDPA MODEM WILL NOT WORK WITH VISTA HOME PREMIUM SP1
Be sure your system meets the minimum System Requirements.
• Standard USB interface
• Microsoft Windows® 2000, Windows® XP or Windows® Vista
• Mac OSX 10.3.7 up to Mac OSX 10.5 32 bit version
• Minimum 50MB of free hard disk space
• Minimum 128MB RAM
• Microsoft Internet Explorer 5.5 or higher
Uninstall or reinstall SP1. Like Windows XP, Vista will not be reliable until SP2.
If you are using the USB modem via a PCMCIA USB 2.0 adaptor, then you will have a power issue. The PCMCIA cannot supply enough current to properly initialize a USB mode (500mA). You will need to get your self a powered hub or get yourself a HSDPA mobile.
Aug 31, 2008 | Computers & Internet
Modem
Yes! the error could be the pcmcia modem card.
A PCMCIA Card is used to connect to your laptop different components that you it doesn't have.
More information about PCMCIA
For most ISPs all you need to connect to the Internet is a network card. Check if your laptop has an integrated network card. Then contact your ISP and ask him if you need something else except a network card to connect to Internet.
Jan 22, 2008 | Panasonic Toughbook Y2 Notebook
My Zonet zfm5600cf pcmcia card did not come with a driver
The currently available drivers for that card can be downloaded here,
http://www.zonetusa.com/download.asp
This should be compatable with most of the current Microsoft Operating Systems.
Jan 20, 2008 | Zonet V.92 FAX MODEM (zfm5600cf)
QUESTION
Yow poeri, i suspect your system is too slow for burning DVD(s). (A) Yuo may need a 2.+ prosser, faster bus speed, with 512 memory, to burn any faster than 2hr. (B) your burn time will depend largely on the duration of your mavie. (C) Check what is the system requiremeent for burning DVD(s).
Mar 28, 2007 | Zonet : CardBus 2-port PCMCIA USB2.0 PC...
Zonet ZUN2200 Issues
I have the same problem when connecting my ipod and usb hard drive. I think the card is just a piece of crap. I've also tried a different card before but had no luck either. I guess its time to get a new laptop.
Aug 24, 2006 | Zonet 2-Port USB2 Cardbus (PCMCIA Type II)...
Open Questions:
See all Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF) Questions
Zonet PCMCIA 56K V.92 Modem (ZFM5600-CF) (MDMZN5600CF) Logo
134 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
