There are a few possible causes for a Kirkland dryer to have a light that turns on but the machine won't run:
- Broken Belt: If the drum inside the dryer does not rotate when you turn it on, it could be a broken belt. A broken belt will prevent the drum from spinning and the motor from operating.
- Blown Fuse or Tripped Circuit Breaker: The dryer might not run if it has a blown fuse or a tripped circuit breaker. Check your electrical panel for tripped breakers or blown fuses.
- Faulty Motor: If the dryer motor has burnt out, the dryer will not be able to run. You may have noticed a burning smell or an unusual noise before the motor failed.
- Clogged or Blocked Vent: If the vent or exhaust hose is clogged or blocked, the dryer may overheat and shut down. This can also cause unusual noises.
- Defective Door Switch: If the door switch is defective, the dryer may not start, even though the light comes on.
To diagnose the problem, you may need to disassemble the dryer and inspect the belt, motor, and other components. If you're not comfortable doing this, it may be best to call a professional technician to troubleshoot and repair the dryer.
