Question about ASUS M2NPV-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
I dont know whether the primary and secondary IDE ports are there in the asus m2npv-vm & m2n-mx motherboards.i am having the HDD which has compatibility of connecting through IDE ports...but the recent motherboards are coming with Serial ATA 2.0 ports.that's why i need to make sure that i can use my HDD with the new motherboard after upgrading to asus...
Hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Posted on Jan 19, 2008
    Brigadier General:
  • 6,966 Answers
Hi, The manual says yes. Specifically, Asus M2NPV-VM has 4 SATA and 2 IDEs, while the M2N-MX has 4 SATA and a single IDE. Manuals for these models are available for download from www.support.asus.com Hope this be of some help. Good luck and kind regards.
Posted on Aug 22, 2007
    President:
  • 1,114 Answers
Yes both boards have IDE the m2npv-vm has two & the m2n-mx has one. See links: http://www.asus.com/products4.aspx?modelmenu=2&model=1138&l1=3&l2=101&l3=0&l4=0 http://www.asus.com/products.aspx?l1=3&l2=101&l3=343&l4=0&model=1338&modelmenu=2 Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE:
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
ASUS M2N MX SE Motherboard
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Jun 18, 2009 | ASUS M2N-MX Motherboard
Need drivers for dis motherboard m2npv-vm for network conection
You can download the drivers for this MOBO from this link http://support.asus.com/download/download.aspx?modelname=M2NPV-VM&SLanguage=en-us
Jun 14, 2009 | ASUS MOTHERBOARD M2NPV-VM SOCKET AM2 NVI...
I dont know how many ram and video support my motherboard
This motherboard supports upto 8 GB of RAM..It already has 512 MB of Video with Nvidea graphics card which is HD compatible. I am not sure if you want to put some more onto it.
Rate the solution as Fixya !
tnx,
AD
Feb 26, 2009 | ASUS M2NPV-VM Motherboard
Ide not work
there may be some problem in the ide cable just change the ide cable and try once .. you can check it by going to BIOS whether after replacing the ide cable the device detects or not ..
if you persist same problem then there may be some problem in the secondary IDE port(may be some pin might have broken or some short circuit might have occured have a check) just take your motherboard to the motherboard technician if so ...
Sep 08, 2008 | ASUS P5S800-VM Motherboard
I cannot find any devices that are connected to my motherboard USB ports
here is where you can find the driver downloads as well as the manual. hope this helps.
Jun 28, 2008 | ASUS MOTHERBOARD M2NPV-VM SOCKET AM2 NVI...
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
M2npv-vm motherboard
The board is a mini-ATX board. As such the ASUS M2NPV-VM board is able to fit into any mini-ATX case or bigger.
uATX Form Factor, 9.6" x 9.6" (24.5cm x 24.5cm)
Jan 08, 2008 | ASUS M2NPV-VM Motherboard
Secondary IDE not working
Try to check if there are some capacitor has been damage. Replace the capacitor in each specific specification. You can do it yourself by using soldering iron.
Hope this is helpful to you.
Please vote me if I'm done correct solution.
Oct 30, 2007 | ASUS A8V-VM Motherboard
ASUS M2NPV-VM Motherboard Logo
349 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
