My Geo Prizm's gas tank keeps building up with pressure and blowing a hole in the tank at it's weakest point. Where is the relief valve and can it be replaced? Would a new tank come with one or is it a separate part? Do they make pressure relief gas caps and would this solve the problem as well?? Thanks
If the gas tank is let low on fuel. This causes presure to build up .The tank can only expand so much before exploding.Check you're fuel cap to see if theres a small hole if so check for blockage. You may need to buy a new cap. i hope this helps good luck,
You have some otyher issue here besides the pressure problem.
SOURCE: 1995 geo prizm gas tank replacement
what is the unit called on top of gas tank where both fuel lines come into the fuel pump?
SOURCE: 1994 GEO Prizm Fuel Guage
You need to replace your fuel sending unit. It is located inside of the gas tank.
Please remember to rate this solution.
SOURCE: 1994 Geo Metro LSI runs very poorly losing power
Was under the impression that this was a people helping people self help free service / can't afford to pay FixYA !!!
SOURCE: Where is the fuel pressure regulator located on a
The fuel pressure regulator. its on the end of the fuel rail. pull the vacuum hose off the regulator and look inside. If the inside of the hose is wet with fuel, the regulator is bad.
SOURCE: engine code 14 ignition signal and code 26 rich
I would start by replacing the primary ignition system,cap,rotors,wires,you can't just check these items they could be defective where you are unable to see.a rich condition can be caused by a mis fire from a wire,a bad tps,or 02 sensor,but I would always start with the basics and not overlook them,if you need any more help let me know.
TIM.................
