Question about Garmin StreetPilot 2610 GPS Receiver
Touchscreen problem The touch screen on my GPS unit is not working right. The left side of the screen is fine, but the closer to the right side you touch it starts picking up the wrong button. IE: if your looking at the keyboard, when you press the letter F, D or S show up (the buttons next to what i'm pressing). It's as if the keys are off track.
  • 6 more comments
  • Anonymous Nov 05, 2007
    My touch screen does not work for menu items. I tried the calibration proceedure and it comes up "calibration failed".
  • Bone Boy Nov 07, 2007
    UNABLE TO INPUT NUMBERS FOR ADDRESS DUE TO THE NEXT NUMBERS COMING UP
  • plydon Dec 09, 2007
    My touchscreen is off center, when I try to recalibrate it keeps giving me a fail. Any thing else I can do?
  • frydavid Dec 11, 2007
    my touchscreen on my 2610 has failed. remote works fine.
  • nk111691 Dec 14, 2008
    thanks for the solution!! I have not been ablet to use my Garmin SP2610 for a VERY long time. We are getting ready to travel and really wanted to use it again. Thanks to the tips on how to calibrate the touchscreen and how to take it apart to clean. If I had not seen the notes about calibrating it numerous times I would not have done my the 7 times it took to finally get to the calibration completed screen. THANK YOU! this site is awesome!!
  • gjslaiby Jan 27, 2009
    my touch screen has stopped working
  • mohdijaz Apr 16, 2009
  • Anonymous Mar 15, 2014
    when touching letters on left side of screen it goes to the next letter
Your screen needs to be recalibrated Press the "Menu" key Select Display When the "Automatice Brightnesss comes on the screen Press the "Find" Key, follow the instructions you will have to touch the dot that comes on the screen about four times and then you will be able to touch all keys when completed
Posted on Aug 26, 2007
I corrected my problem. It was a pain, but I pulled the thing apart and cleaned the screen around the edge of the frame. It had alot of dust and particles there. Put it back together and with one calibration it works fine.
Posted on Dec 17, 2007
Mine isn't working at all. When it asks to presson the red dots, nothing happens????
Posted on Sep 29, 2008
I have performed the calibration (3) times. When I go back into the car during high heat, the problem reoccurs. My remote will not work. I point it at the eye and nothing happens. Anyone have a solution for my remote?
Posted on Aug 11, 2008
Touch screen not working at all
Posted on Jul 20, 2008
June 9, 2008
Yes, Yes, Yes it worked. I love my Garmin. I had received permission from my wife to use her Tom Tom. Then, I found this web site and fixed my screen. I am a traveling salesman and need to use it daily in my work. Thanks for the help!
Posted on Jun 09, 2008
FIXED!!!
Wow.. I couldn't believe it.. sigh.. i took this post (see below) from a solution to a 2620 Garmin. and YES.. it worked..
Well.. after running all the diagnostics nothing much happened.. I had done that before.. the part that really helped was the idea (as stupid as it sounds) to keep on running the screen recalibration test, after I did it continously on the 5th time the problem was fixed and my touch screen is back to normal.
I hope this helps..
(8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the pointsTouchscreen problem - 1.gif indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9).
Posted on Dec 15, 2007
    Problem Solver:
If you get the "calibration failed" message, you can always use the remote. I'm convinced the 2610 is heat sensitive, as the problem only occurs in hot weather.
I have had this problem and others with my 2610.
Posted on Nov 20, 2007
SOURCE:
Had my Nuvi 1350 plugged into the 12v outlet on my delivery truck. Was on a delivery about 10 miles away/Garmin working fine. Stopped at rest area. Shut truck off w/Garmin still plugged in. When I...
We can tr to do a reset on the unit, follow this steps.
Start with the unit OFF and unplugged from power Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil Continue touching and holding the lower right hand corner of the screen then power the unit ON.
But if the unit still responding after that , its definitely fried and if its still under warranty better have it replace.
Aug 08, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin gps keyboard -- left upper corner fails to work when press ''A'' is C and others on left side are incorrect also. How do I fix?
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute. 3. A screen will display that says, Press dot in the lower left corner. 4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
Sep 19, 2009 | Garmin zumo 550 GPS Receiver
Touch screen needs to be calibrated (i.e., when typing an "a", I might get an "o", or nothing at all. Same applies to numbers. I was unable to get to the calibration screen following instrucitons in...
That is actually how you should do it, it's just that it's very hard to succeed. Personally I have to try 3-4 times before making it work. The "trick" is to start touching the screen right after it was turned on, but right before locking it, but still locking it right after it was turned on.
It's stupidly hard on this specific series for some very weird reason.
Also, since it seems to be very calibrated to the left, try pressing far left on your screen, so the touch is registred too, don't know if it helps, but possibly.
Jun 18, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
On my gps when i touch the left side of my screen the right
is there a callibration option ? if so it may just need callibrating for touch screen again.
May 14, 2009 | Tomtom ONE 3rd Edition GPS
Touch screen wont work
Try resetting the unit. Oppisite side of on switch (left side) lift rubber cover, notice the button and slide switch. With unit on,use a pen and slide the switch up and then back down and trhen hit the button on top. that should rest the unit. Also you look in the manual for reset.
Apr 04, 2009 | Magellan RoadMate 2000 GPS Receiver
Gps loading screen freezes
If Magellan touch screen, try turning unit on while holding bottom right corner of touch screen. This will reset the unit.
Jun 27, 2008 | Magellan Maestro 4040 GPS Receiver
Touch screen not working properly
I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
Mar 11, 2008 | Garmin zumo 550 GPS Receiver
Touch screen does not work
My c330 has a reset button if you take the outer frame off, and it's on the right hand (center) side. Also, I was having issues with my screen too. I work in construction, so I cleaned it around the screen and found a small piece of something which was obstructing my path. I cleaned it, and it works fine.
Dec 19, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
1,393 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
