Question about Philips Magnavox DVD Player MWD200F
Wont spin dvd player was dropped in a move. when i tried to use it it said it could not read dvd. i opened to pf player and the dvd was not spinning, i was able to get a could to start spinning by starting them with my finger but now they will only start to spin then stop
  • cdfreeze Aug 22, 2007
    ive popped it open all ready and i cant find anything that looks like its broken, i was able to get about 4 dvds to read after it was dropped by taking off the cover and manually starting the spining but now that doesnt work
  • Anonymous Jan 01, 2008
    DISC DOES NOT SPIN. BY PUSHING THE DISC IT REVOLVES FEW TIMES AND STOPS.
    LASER PICKUP SEEMS TO BE SEARCHING, BUT THE DISC WILL NOT REVOLVE. I CLEANED THE LASER LENS TO NO AVAIL.
    IS THE LASER PU NG. IS IT WORTH TO BUY A NEW PICKUP?
    PLEASE ADVISE.
    MY E-MAIL LKRANC@OPTONLINE.NET
    THANK YOU.
Cdfreeze, DVD drives spin up the platter and attempt to read from it. If the read fails, they stop spinning the drive. So, I think the problem you have is that the device won't read. DVD drives have some very small plastic pieces that can break and cause failure. They also have a read head that can get out of alignment. If you're ambitious, look at the drive and see if you can find any other damage. Don't run the drive open, though, because there is invisible laser that can blind you (there should have been a warning on the top of the drive when you opened it). I checked eBay and this DVD player sells for under $20 (including shipping), so don't spend too much time on it. Definitely let me know if you have questions or comments.
Posted on Aug 22, 2007
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Hi My denon does not read any discs at all. The lase lights up 2 or 3 times and it tries to spin but only moves very slightly. I have tried to look for laser but the parts companys say I have to get the...
the whole assembly is sold for a reason.
it is almost impossible to align the laser without expensive equipment.
the disc motor has a small bearing on the top,put a drop of oil on it and spin the clamper until it is really free spinning.
disc motors are small and fragile,and can cause a no read situation from a slow spool up.
Sep 01, 2009 | Denon DVD-2910 DVD Player
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
Audiovox MVDVD4
Just stumbled upon this as I was searching for a new MVDVD4 and thought it might help you out!! :
When the van was a little over 3 years old, the DVD player suddenly quit working. I would put in a DVD, the player made some noises like it was trying to read the DVD, then the display would say "NO DISK".
As it was out of warranty and I have a background in electronics, I opened the player. After playing around for a little while, I was able to fix the player real easily. If you have the same problem (and the player is out of warranty), open up the DVD player by removing the screws and breaking the seal. I blew out the inside with compressed air, but I doubt this made a difference. The problem was that the DVD was not spinning. The spinning mechanism under the DVD tray was not starting like it should. I carefully sprayed a couple drops of WD-40 (well actually Remington's Rem Oil) where the metal rod the spinner sits on goes into the motor mechanism that spins it (it will make sense when you look inside. It is where the little metal rod goes into the plastic casing). After a couple of drops of oil, the player worked fine again.
Mar 02, 2008 | Audiovox MVDVD4 Car Video Player
Bad Disk
If you find that the DVD is not spinning it might means that the the "spinner" is not functioning, the sound you hear is the laser moving up and down trying to read your DVD but since is not spinning it can not read it. You will need to replace the small motor that operates the spinner, after extensive use they just give up. I hope this is helpful enough.
Aug 30, 2007 | Polaroid PDM-0082 Portable DVD Player
I put a disk in and it just keeps loading...
Have you dropped your player? I dropped mine and I am experiencing the same problems. I'm trying to find information on how to fix it.
Apr 29, 2007 | Philips PET710 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Philips Magnavox DVD Player MWD200F Logo
369 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
