Sony PlayStation 2  Console
Problem for Sony PlayStation 2 (PS2) Console
Disc wont read
By detwon98 on Aug 22, 2007
hello every time i put a game in it spins for a long time and eventually it says no disc or disc not reading.
Clarification Request
Posted by xcod4sniperx on Apr 14, 2009
I know how to fix your ps2, first you must tell me if it is an old, fat one, or a newer skinny one. (I only know how to fix a fat one so...........tell me if its fat or skinny.
Same Problem
May 14, 2009
-   wont spin discs
-   Guest
Apr 05, 2009
-   when i put the disc in the ps2 it just keep spinnig
-   Guest
Apr 01, 2009
-   it doesnt reads cd's -   Guest
Mar 29, 2009
-   my disc spends for like 10 minutes and then it says insert a ps2 format disc. it's really starting to **** meoff-   nj3_rob4
Dec 05, 2008
-   i put a disc (ps2, movie, music cd, it doesnt matter) in the system, and it leaves a scratch all the way around the disc. thought it was becaus the disc was not properlly placed, but thats not it. what can i do? -   wickedwyt1
Best Solution
posted on Aug 22, 2007
Helpful)
WHOINTHE812
Rank: Apprentice
Rating: 85%, 15 votes
1. Intro
2. Warnings
3. Diagnostic Mode
4. Cleaning the Laser
5. Do I need to adjust the voltage?
6. Clicking and Squeaking explained
7. Adjusting the Voltage
8. Disclaimer
9. Contact
10. Credits
(multiple sections are contained on each page, scroll down if you don?t see the data you want)
**********INTRO:
*You might wonder why your PS2 isn't working. Well, if you're getting Disc Read Errors on multiple discs, all of which appear to be in good condition, then you most likely have one of two common problems. Either your laser is being obstructed by dirt and dust, or the laser's voltage is not properly adjusted.
*Note: that this FAQ was written for people with little or no knowledge of electronics. The technical-speak has been highly simplified for those without the electronic know-how.
************WARNINGS:
*The Playstation 2 is a precise gaming console. Fixing the console yourself should not be done unless completely necessary. You may also risk electric shock, so do anything within your power to remain safe while attempting these repairs.
*If you can, use an anti-static wrist band to ground yourself. This device is available at any electronics store (e.g. Radio Shack.)
*These repairs require opening the case, which WILL void your warranty. If your console is still under warranty think twice about cracking the seal.
*Adjusting the laser's voltage requires some precision, being too rough can cause damage which you will not be able to fix. Be very careful when doing this process!!! Be prepared to pay Sony over $120 to fix this part if you damage it!!!
*Always attempt the laser CLEANING before trying to adjust the voltage!!!!!
***********DIAGNOSTIC MODE:
This is the easiest thing you can do to attempt to fix your PS2, while it hardly ever works it only take a minute or two, and should be done first before you take apart your machine.
1) You must be in the "main menu" screen of the PS2 console, the first screen that comes up when you start with no disc in.
2) Press the "triangle button"
3) Select "Console" from the top using the up directional buttons and press the "Triangle" button
4) Select "On" using the up and down directional buttons and press the "X" button
5) Insert a disc. The console automatically starts the diagnosis.
***********8CLEANING THE LASER:
*Required Materials:-Normal Phillips head screwdriver-Jewelry (Small) Phillips head screwdriver-Q-Tip-Rubbing Alcohol (Isopropyl)
*Optional Materials:-Can of Air-Butter knife
*Taking the PS2 apart is fairly simple, nothing too complicating. All that you're basically going to do is remove the upper shell, remove the lens cover, clean the lens, and put everything back together again. Just be sure to follow the steps, and read through each step and understand it before going through with it. Sometimes the instructions may seem a little too in depth or complicating, but just use your common sense and you should understand what I'm trying to say. It's a lot easier if you print it out, as well.
1. Make sure that you have a neat, clean area set aside for taking the PS2 apart. A small box or cup to put screws in wouldn't hurt, either. Flip your PS2 over so that the bottom (horizontally speaking) is facing up. There should be 6 screw covers, 4 plastic and 2 rubber, that need to be removed.
You can use the butter knife for this, or your nails, whichever is easier.
Screws should be uncovered under them. There should be 2-4 more screw covers on the outer side of the base, underneath the controller ports (where the system goes out a few inches from the base). The older model PS2's have 4 screw covers, while the newer ones have only 2. Remove them all, and you should now have a total of 8-10 screws unveiled. Set the screw covers aside.
2. Using the normal sized Phillips head screwdriver, remove all of the screws. REMEMBER where the longer screws go, or mark the holes with a piece of tape or anything that will remind you of which holes the long screws go into. If you do not remember where the long screws go, you could put a hole through a circuit board by trying to force the long screw in where it is not supposed to be. Make sure all of the screws are removed, and put them aside.
3. The PS2 shell should now be ready to remove. ONLY the UPPER side (with the PS2 logo) needs to be removed to clean the lens - Leave the BOTTOM side on.
***But, be very careful when taking the upper shell off, or you could damage the PS2. To take the shell off, you first should place the PS2 horizontally, with the PS2 logo facing up.
*Next, you need to move the side of the shell out a little, sideways, so that the Eject/Reset buttons are not blocking the shell, and it can be lifted off. Just play around with it a little and you should get it. Then, lift it at an angle, like opening the cover of a book. Take the bottom (Vertically speaking) of the shell, with the PS2 logo on it, and lift it an angle.
You should notice a small wire around the area where the Reset/Eject buttons are. The wire should be taped to the top of the Lens cover. Remove the tape, and then carefully lift the cover so that it is laying flat, and the PS2 is open like a book, connected at the middle by the wire. The Lens is now almost accessible.
4. To gain access to the lens, you need to remove the lens cover. The lens cover is located right in the area where the PS2 ejects the tray out, just above the tray. It's square shaped, and has a small white circle piece on it.
To remove the lens cover, simply take out the 2-4 screws located on the side with the Jewelry screw driver. Place the screws aside, and lift the lens cover. You should now see the lens, a small circular glass piece located in the back of the disc tray.
***Optional***
Now comes the optional part. If you have a Can of compressed Air, you can use that to get all of the dust out of the PS2. Spray all around the area, especially the fan. You don't need to remove anything, just spray. When it seems that the dust is removed, go on to step 5.
5. Now, the lens can finally be cleaned. Take the Q-Tip and swab it generously in the rubbing alcohol, but make sure that there's not too much on it so that it's dripping. Take the Q-Tip and carefully yet firmly rub the lens in a circular motion for a good 30 seconds. Then, flip the Q-Tip over to the dry side and dry it off in the same circular motions. The lens should now be clean.
6. All that's left now is putting the PS2 back together, which should be fairly easy. Place the lens cover back on, making sure that it's tight and snug in position. Screw it in place. Then, tape the wire back onto the lens cover and flip the shell back into place on the PS2. Screw the screws back in, making sure the longer screws are going into the correct holes. The screws don't all have to be tight, so don't sweat it if 1 or 2 of them aren't seeming to fit into the holes all of the way, as long as they're in the right holes. Put the screw covers back into place, and you're done.
Congratulations, your PS2 is now cleaned, and working like new, without having to spend a dime! Feel free to repeat this process in the future, as well, if Disc Read Errors ever occur again.
*********DO I NEED TO ADJUST THE VOLTAGE?
*To determine whether or not these repairs are necessary, read the following carefully...
*You may need to adjust the voltage if:
1. Your PS2 reads games on DVDs but will not read games on CDs
2. Your PS2 reads games on CDs but will not read games on DVDs
3. Your PS2 will read no games, you have already cleaned the laser and you are using undamaged discs.
*****Do not adjust the voltage if:
1. You do not receive the message "Disc Read Error" in the browser screen when trying to load problem discs
2. You have a Playstation 2 Version 4 or higher: a PS2 with 8 screw covers on the bottom rather than 10. (Directions for fixing these models will be available sooner or later)
3. Your PS2 only gets errors on certain CD or DVD games, not All CD or DVD games. Try cleaning the problem disc, or using a Disc-Doctor
4. You receive "error reading CD" during games such as GTA3/VC or other games that stream data (clean the laser in this case)please note that fine tuning may be needed if your PS2 reads CD games but not audio/PS1 CDs (or vice versa)... Or if your PS2 reads DVD games but not DVD movies (or vice versa)... Personally I don't suggest fine tuning without a voltage meter.
********CLICKING AND SQUEAKING EXPLAINED
*Clicking is most likely the laser unit moving back and forth trying to access a piece of data. If it can't find that data it will move back and forth until it does. In the case of a DRE, since the PS2 never finds that data it will continue clicking until you receive the error.
*In case clicking is loud, or you hear squeaking, it might be a good idea to clean the slide rods that the laser rides on, and then add some oil or grease.
*Loud clicking can be the result of warped discs in the drive, check to see if your disc is warped if you get loud clicking.
********ADJUSTING THE VOLTAGE:
******Read these instructions all the way through, and make sure you understand all the steps before doing anything!
1. Remove your warranty sticker, located next to the power cord. Take off the cover to the expansion bay.
2. Remove the screw covers on the very bottom of your Playstation 2. There are six total. Four of them will be rubberized and two will be plastic. You may need a flat head screwdriver to remove the plastic ones. Ignore the extra 4 plastic covers on the raised, upper portion of the underside of your PS2, these are for removing the top shell.
3. With a phillips-head screwdriver remove the six screws under the covers you just took off. Four short and two long.
4. Pull up on the bottom portion of the case to remove it.
5. Remove the metal shield covering the circuit board (the shiny one). With the front of the PS2 facing toward you, it is on the right. There is only one screw holding it in place, it has an arrow pointing toward it.
6. Remove the expansion bay plate (the dull one with holes). With the front of the PS2 facing toward you, it will be on your left. Once again there is only one screw holding it in place with an arrow pointing toward it.
7. Lift out the expansion bay housing. It is attached to the circuit board by a short ribbon cable. Under this are the laser control screws.
8. The laser control screws are on a small amber circuit board slightly recessed in the plastic case. You will be adjusting one or both of the two small silver screws with a black screw in-between them.
*With the front of the PS2 facing you, the silver screw on the LEFT controls the voltage for the CD reading. The silver screw on the RIGHT controls the voltage for the DVD reading.
****I suggest putting a small dot, with a sharpie pen, in the 12 o'clock position of each screw to help with the adjusting process...
9. Stand the PS2 on its side (vertically, memory cards at bottom, power button at top) at a slight angle. You won?t be able to stand it at this angle unless it is done on carpet floor. Having a friend hold it in position might be better. Make sure that the expansion bay housing does not come in contact with the circuit board, as you will be turning it on, and you don?t want the metal housing to short out the board. Let it hang down, away from the board.
10. With the PS2 plugged in (power and video) turn it on. You are ready to adjust the voltage for the laser. Only adjust the screw for the type of disc you are having problems with. If you are having problems with both, do them one at a time. Remember, now that the unit is on its side the CD voltage control screw is above the DVD control screw.
***If at all possible use a non-metallic screwdriver, as static electricity can ruin this portion of your PS2 (a $65+ part!)...
11. Turning the screw clockwise increases the voltage, counter-clockwise decreases the voltage. Because you risk of blowing the laser if you give it too much voltage, always start by decreasing voltage. In my experience, you generally have to add voltage, but for safety, I suggest you reduce voltage first.
*Using a small screw-driver (non-magnetic & non-metallic if possible) turn the appropriate screw counter-clockwise two degrees. Load in the CD and wait, if you still get a disc read error move the screw another two degrees. Repeat the process...
*If you still get disc read errors after about 20 degrees of rotation, put the screw back to the 12 o'clock position and start moving the screw clockwise two degrees at a time.
*It may take a while, but you will most likely find the sweet spot where your discs begin to read again. I have never had to move the screw more than 30 degrees, although I have heard as much as 180 degrees are needed for a modded PS2 to play backup CD-Rs.
12. Try a few different trouble discs before re-assembly to make sure you don?t need more fine adjustment. As well, hold the PS2 elevated in the horizontal position and make sure it reads while in this position. I have found that slightly more voltage (2-6 degrees) is needed to run discs in the horizontal position than the vertical position.
13. Turn off the PS2 and re-assemble it.
If All Else Fails You Can Contact Sony:1-800-345-7669 This is the number you need to call if you?re getting Disk Read Errors. Sony may fix it for free even without a warranty. They will not fix it if you have installed a mod-chip. If you installed one, just forget about getting this repair. They will still fix it if you took the warranty sticker off. The warranty sticker is not important to this repair since it only voids the warranty when there is one. Since most of the people taking advantage of this have not had a warranty in years. If Sony repaired your PS2 in the past, but the Disk Read Error came back, do not worry, they will still do it again for free, they may even replace it with a new one. When you call Sony you need to talk to a real person. This is the Sony hotline, so there are a million recordings. Just listen for the option to talk to a Customer Service Representative and select that. While talking to them, make sure you specifically mention that you are getting a Disc Read Error. Those are the "magic" words, you will not get very far without saying "Disc Read Error." After this they will ask you some questions such as if you have used any devices such as a Gameshark, answer no. They will also ask you if you have used a cleaning device on the game disc, say no. They ask a few more questions but those are the important ones. Once you get the go ahead for the free repair simply follow the instructions they give you. They will ask you if you want to write down the information or have them email it to you. I suggest having them email it to you since it will have the number that gets you the free repair already written on top and it has all the blank spaces for you to fill in the necessary information so you will not forget to put anything down. The repair is free but you will have to pay for the shipping to Sony. However they pay for the shipping on the way back. I would suggest that you purchase insurance, you do not want to loose your PS2 just so you can save a couple of dollars.
Their repair time is generally short.
Comments:
Aug 22, 2007
- THIS IS WHAT'S FOR SALE IN THE SIDEBAR
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
Somewhat Helpful)
ansfarid
Rank: Guru  Sony Expert
Rating: 89%, 201 votes
Clean the lens with alcohol otherwise replace the lens with a new one.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 19, 2008
Somewhat Helpful)
troblefollow
Rank: Master
Rating: 71%, 8 votes
my ps2 did that once so i smacked with a hammer and bought a slim one
Was this helpful?
Yes
No
Solution #4
posted on Mar 01, 2009
Very Helpful)
chris14254
Rank: Apprentice
Rating: 93%, 7 votes
IF you have a really old ps2 it could only read purple discs not the clear discs hope it helps
Was this helpful?
Yes
No
Solution #5
posted on Dec 06, 2008
Very Helpful)
krazy j
Rank: Apprentice
Rating: 100%, 3 votes
ive been through the same prob i went to youtube put ps2 disc read error i did all the steps it worked you just have to take off all the plastic things in the bottom unscrew all the screws and when you opend it there is going to be something covering the disc tray unscrew all the screws again with a knife then there is going to be a little white thing you just clean it with rubbing alchol and fixed
Was this helpful?
Yes
No
Solution #6
posted on Aug 07, 2009
Somewhat Helpful)
lailaha
Rank: Master
Rating: 79%, 23 votes
Try this link . . . http://www.Sony.com/PlayStation2PS2Consol
To find your best solution.
12
Was this helpful?
Yes
No
Solution #7
posted on Oct 26, 2008
Somewhat Helpful)
moonlitet55
Rank: Apprentice
Rating: 75%, 1 votes
will not read disc noyhing comes up make a wurrrrrr noise
Was this helpful?
Yes
No
Solution #8
posted on Sep 10, 2008
Somewhat Helpful)
C_romon028
Rank: Apprentice
Rating: 75%, 2 votes
all i get is errors
so i did the hammer trick
ya its where you hit it with a hammer and then through it down some steps
it really works
peace
Was this helpful?
Yes
No
Solution #9
posted on May 20, 2008
Somewhat Helpful)
Sharper1106
Rating: 87%, 53 votes
9 out of 10 times when the fat ps2 cant/wont read disk its the cd tray needs to be adjusted.
I would suggest opening up the ps2 and cleaning the console with Qtips and rubing alcohol. if the laser will wont read. go to youtube.com type in fix my ps2 laser. you will watch a video on how to adjust your cd tray.
The reason for this issue is if the laser is to close or to far from the cd the laser cant read the cd.
contact united.gamez@gmail.com for help
Was this helpful?
Yes
No
Solution #10
posted on May 07, 2009
Not Rated)
Seritath
Rank: Wiz
Rating: 81%, 40 votes
Detwon,the only thing I can think of is your laser reader is smudged or scratched.The horrible part about this is you cannot clean it or unscratch it seeing as any liquid that slips by could fry your whole systeme.You might have to get it fixed which probably is costly.Either that or a wire connection to your processor is lose and you will have to take it apart and splice the connection back together.Thats all I can think of.
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation 2 Console
Questions and Unsolved Problems for Sony PlayStation 2 Console
Do you recommend Sony PlayStation 2 (PS2) Console?
Answer
Answer
how to get playstation 2 live
Answer
don't know how to save high scores to memory card
Answer
I'm playing Mana Khemia 2 and when I save the memory card is corrupted and then I can't use the card... (More)
Answer
The electric strip that connects to the reset button has come apart. how do i fix it
12 Other Users Have The Same Problem - Continued
Comment by terrell687, posted on Nov 24, 2008
its not reading any of my games
even the new ones
Comment by josh432, posted on Oct 27, 2008
disc read error
Comment by sargent_jp, posted on Jun 22, 2008
i put in a disc, and it dousnt read it.
Comment by lilr0cket, posted on Mar 05, 2008
my ps2 wont read ps2 games but it will read playstation 1 games what should i do?
Comment by Packers, posted on Mar 05, 2008
Put Disc in and it goes to the browser menu each time
Comment by deb1955, posted on Feb 23, 2008
when i put in a movie to watch the loading takes a long time and then it comes up NO DISC. I have only used it 4-5 times. HElp !!!
Comment by wonderweasel, posted on Dec 31, 2007
disc wont read i beat my ps2 to a pulp.........and i miss it...oh well
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony PlayStation 2 Console:
Top Timer Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Timer Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
