Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Water will not drain away at end of wash programee
I think the water pump is blocked but don't know how to get access to it to clean it out. The user manual shows a picture of a removable cover where the filters are but my model does not appear to have this, The manual also has an asterix which says some models only on the water pump section. I have also checked the outlet pipe and there appears to be no blockages so concluded that it is the pump blocked. How can i clear it?
  • 909 Answers
METHODS TO REMOVE COVERS ON EACH MODELS ARE DIFFERENT. BASICALLY, REMOVE THE LID FIRST THEN CHOOSE WHICH COVER(S) YOU WISH TO REMOVE. FOLLOW THE PERRIMETER OF THE COVER AND REMOVE ALL THE SCREWS SECURING IT. ONCE SCREWS ARE REMOVED, SLIDE COVER OFF AND INSPECT FAULTY COMPONENT.IF YOU CANT SEEM TO GAIN ACCESS TO THE DESIRED AREA, I SUGGEST A TECH. BECAUSE THE BASE WOULD HAVE TO BE SEPERATED FROM THE BODY CAUSING CAUSING FLOAT SWITCHES ETC TO FALL OUT. NOT FUN IF NEW TO IT.
Posted on Aug 23, 2007
SOURCE:
I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Nov 08, 2015 | Haier Washing Machines
Kenmore 800 water in tub at end of cycle
This could be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Washing Machines
Washer is full of water. drain is blocked with hair or lint i believe. washed some nasty stuff. wont drain. how do i clear the blockage? i think may be blocked inside washer. drain hose is very narrow...
If you can get a garden type water hose near there, try to carefully use it to blow the water backwards through the drain hose. Put the hose up to the drain hose end and wrap a rag tightly around it and turn the water slowley. This may free up any debris from the hose and pump. If anything comes out,clean it out of the tub before you turn it back on.
Sep 02, 2011 | Kenmore 2.1 cu. ft. Portable Top Load...
Front loader has stopped mid wash and red light has come on saying clean my pump. How do I do this?
Not knowing which model you have makes it a bit difficult. Most front loaders have a little trap door down on the front panel somewhere. Behind this door is access to the pump filter. Usually, it just unscrews, and you pull it out. If your machine is full of water, expect a mess. remove any buildup of fluff, foreign objects etc. If your machine has no trap or access. Unplug the machine and drag it away from the wall. Lean the machine back against the wall to gain access underneath. You should be able to see a large hose from the tub to the front ( or side) of the pump. They are usually held on by a spring clip. Slide the clip back or unscrew the clip to enable you to pull the hose off the pump. Clean out any foreign objects you find. As before, if the machine is full of water, expect a mess. Front loader drain hoses usually exit out the top of the machine so lying the end of the drain hose on the ground wont drain the water.
Jul 26, 2011 | Whirlpool Washing Machines
Water won't drain away from the drum. I think I may have a blocked filter. How do I access to clean the filter on a Hotpoint WT960G washing machine please. Many thanks.
Most Hotpoint washers do not have a customer accessable drain cleanout. Also, it may be a full or partial pump failure. Replacing the pump assembly will improve washer performance.
Replacement pump is about 20 Pounds delivered, and can be self installed quite easily.
Link to video
May 03, 2011 | Hotpoint Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Where is the pump filter on a front loading ge washing machine Model # WCVH6260FWW
The filter (or clean out trap) is located on the drain pump. To access, just follow these steps:
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe.
For reference, you can view some excellent exploded view diagrams of your washer at appliancepartspros.com. If you have any questions about this procedure, please let me know. I hope this helps you.
Oct 27, 2009 | GE WCVH6260FWW
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Cannot get access to Water pump to clear it.
the sump is in the bottom center front. a retangle screen with a center filter should unscrew counterclockwise the drain pump is hard to access but if you want to let me know and I can walk you thru it..let me know if this helps
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
241 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
