Question about Kenmore 22422 Top Load Washer
Agitator I have a 90 series Kenmore and in the wash cycle the agitator makes a ratcheting sound intermittently.
Faultly agitator spline or gear box fault. Regards Advisor
Posted on Aug 22, 2007
Kenmore 90 series top load washer: won't agitate or spin
Sorry to give you bad news but this sounds too much like the transmission is shot. It's a bit of work to change and probably some luck to find one at a reasonable price, so my advice is to ditch this machine and get another. :(
Oct 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore 90 series top load washing machine, when it goes into the wash cycle, the aggitator functions , but jerks and makes a clicking sound. Also, causes the lights to blink in the house. I...
Get a repairman in to check for a damaged drive train on the washer and an electrician in to check the wiring in your house
Switching a high power electric shower on can cause some voltage drop which in turn causes the lights to dim for a short period.
But having a washer stalling on wash doing it sounds as if you have some major issues with the house wiring.
May 29, 2009 | Kenmore 22422 Top Load Washer
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
The agitator works intermittently
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Agitator problems
sounds as if the transmission agitator pawl is slipping. inside the transmission is a gear connected to the agitator. there is a spring loaded pawl that rotates around the center and engages its pawl or hook into the agitator gear for each rotation. either the pawl hook is worn or the agitator gear is rounded off. the transmission must be opened up to see what is a miss
Aug 22, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
90 people viewed this question
Sal De
 Brian Main
Brian Main
