Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
Toshiba 55" rear-projection TV Cinema Series - HDTV (1080i, 480p)compatible Model: 55H70. Bought it in March 2001. Problem: If I turn OFF the TV via the remote control or pushing the ON/OFF button. It will turn OFF. But when I go to turn it back ON, the red power light on the front just blinks. So I have to unplug it from the wall and plug it back in...then I can push the ON/OFF switch to turn it ON. Can you give me your opinion on what is wrong?
  • 1 more comment
  • cwmmgm Oct 31, 2007
    Here's a resolution that I received.  I have not done the repairs yet.  So I'm still unplugging it to turn it ON.
    It sounds like your convergence IC's are going out.
    This is a common problem. There are two IC'c that control multiple functions and they are a high failure part due to running hot. There are also some resistors in that same circuit that will sometimes overheat and change values. The only other thing it may be is a yoke going bad, which is a copper coil that fits over the tubes. I've seen two yokes go bad compared to 100's of convergence IC's so its more than likely the IC's. You could wait until it completely quits working, or you could fix it now, but it will only get worse. You are not really doing any damage by playing it like you are, its just an inconvenience. The total cost to repair the convergence circuit would be $225, and if it was a yoke it would be $25 more. I have all the parts in stock so if you decide to fix it let me know and we'll schedule a time. Thanks for your inquiry.
  • Bartone Dec 26, 2007
    I have the same problem, it will turn off and 3 seconds later go out and flash and then it must be unplugged. Can I fix it at home
  • Anonymous Mar 13, 2014
    wont turn on 55 Toshiba tv
    President:
  • 4,402 Answers
Sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 25, 2007
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
Jan 04, 2011 | Toshiba 62HMX95 62" HDTV
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba tv model Cinema series HDTV Model# tn55x81
my thought is that it's something with the closed captioning, fiddle with those settings in the menu, or with the devices like VCR or DVD if you're using something like that as a tuner.
Nov 16, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
453 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
