Question about Frigidaire FDE336RE Dryer
Overheating dryer If I have only a couple items in the dryer it cycles the coil on and off but if I put in more clothes it just burns up.
  • skeeter41 Aug 23, 2007
    Thanks but I give up!!! I replaced the cycle thermostat and it still does not cycle with 2 towels and a t-shirt in it. I am going to have to buy a new one as this impacts life way to much over a piece of junk like a dryer. I have tried everything every night for a week and can no longer take the heat. This dryer is trying to burn down my house but I am pulling the cord!!!
    Novelist:
    Champion:
  • 244 Answers
Sounds like it is over-heating with a few items in it has more air-space in it with more items it has less air-space i would replace your thermostats this will re-solve your problem some stats go down but some just go faulty and its the faulty ones that are the problem m8
Posted on Aug 23, 2007
  • peter gittos
    peter gittos Aug 24, 2007
    ok m8 sorry i couldnt be any help to u usual solve most problems if u have anymore problems let me know i do dryers washers and types of fridges
SOURCE:
Problem code F22 flashing
http://www.appliancepartsquick.com/MaytagBravosDryerFaultCodes.html exhaust thermister in simple terms is a small round can shaped sensor which turns on/off heating element as the air temp exiting machine rises or falls to stop machine getting to hot and burning out components,reletivly cheap to buy and faily easy to fit depending on youre capabilitys ,if in doubt call a friend who can help or quallified engineer
Dec 31, 2013 | Maytag MEDB400VQ Dryer
Hello: I have a tenant who is having problems with a GE Spacemaker washer/dryer -Stylemaster # is 622866-A. Here is how she describes the problem: ...it seems as though the washer isn't functioning...
If a spin and drain problem you can pull the front off to see if perhaps a small item (ie. sock or like size item) is stuck between basket and tub or in the drain hose? If it is a wash time problem that would be another direction.
Oct 06, 2010 | GE Spacemaker Washer and Dryer Electric...
My LG dryer takes two cycles to dry the clothes
check the dryer vent to make sure it is clear. is there any heat, if not the thermostat or heating coil burned out.
Dec 06, 2009 | LG DLE2532W Electric Dryer
Dryer flame turns off after a couple of minutes leaves clothes damp
HI, this is the result of a faulty set of gas valve coils.(black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
There are also a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance as well. Replace the defective thermostat.
Jul 19, 2009 | Dryers
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Dryer is leaving burn marks on clothes on any temperature.
change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
