Question about HP iPAQ H5555 Pocket PC
HP ipaq 5550 - Bluetooth error
Hello, I have a problem getting the bluetooth manager to work on my Pocket pc. The error message is... The bluetooth radio failed to turn on due to insufficent driver memory available. You must perform a normal reset before you can turn on the bluetooth radio. I have tried the reset and updated the firmware. It use to work. I left it for a while and then started to use it again. Do you have any idea how to fix the problem? Thank you
  • rambiz Aug 23, 2007
    I have reset it back to the original state with no luck as will. It's werd that after sitting for a short period it has done this. The memory is fine.
    Any other ideas?
    It shows that error message everytime I try to access the bluetooth manager. The light is on and the bluthooth says that it's on. Very weird.
    Novelist:
    Scholar:
  • 114 Answers
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Posted on Aug 23, 2007
  • Anonymous Aug 23, 2007
    Check you don't have BlueTooth set to discoverable as if you do everyone in range will likely be accessing/trying to access your device and this can result in something similar to a DOS attack.
    However if your getting the same problem after a hard reset this suggests a hardware fault, contact HP to find out about your warranty status and repair route.
    In that case I'm going to stick my neck out and say it is a hardware fault, so contact HP.
    Don't forget however that PocketPC/Windows mobile are just as poor quality (if not more so) as Microsoft's other products and a future update may or may not resolve the issue.
SOURCE:
Xv6700 phone won't make calls "a wireless radio must be attached"
I HAVE THE OPPOSITE PROBLEM, I WANT WI FI TO WORK WITH OUT PHONE SERVICE ACTIVATED. IS THIS POSSIBLE?????
Jul 23, 2010 | Audiovox XV6700
Dell Inspiron e1405 bluetooth disabled
If it doesn't show in device manager than it doesn't have a driver, you will have to reinstall, go to the link below, download and install, ALL, the correct files for your version BT, Bluetooth files there, that should fix it.
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_E1405&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Feb 26, 2010 | Dell Inspiron E1405 Notebook
Will not bluetooth
"The bluetooth radio failed to turn on due to insufficient driver memory"
Rename or delete BTSDKCE30.dll and BTCORELF.dll in the windows directory of PDA
Jan 18, 2009 | HP iPAQ HX4700 Pocket PC
Bluetooth setup
are you in USA?
if yes, why use such and old device here.
its mostly useless now. with no support.
my guess is out of memory , remove programs to free up memory.
or it needs larger memory,, buy more?
why not ask in a REAL HP forum ?
id love to hear what good this thing can do in 2017....
https://h30434.www3.hp.com/
Jun 07, 2017 | HP iPAQ H2210 Pocket PC
Turn on bluetooth
When this happened to me I did a power cycle reset by removing and replacing the battery. When I turned on the bluetooth after this it turned on OK.
Feb 26, 2008 | Orange SPV M2000 Pocket PC
Bluetooth initilizing problem
broken for 13 years. ok
what OS, ? XP?a the 100% dead OS? that?
what HP PC? full model name, like DV6-1234us.(full)
what blutooth radio, is it 13 years old too?>
what size memory is there, (cp +system)
then look in task manager see memory usage and free mem.
then go to startup folder (msconfig) and get rid of all memory hogging software in there, most are useless
many are, like this.
Adobe update nag
Nvidia update nag
xxxxx update nags. (all useless and memory waste big time)
ccleaner nag ,etc ((does auto cleans so, may be useful)
I only allow my , protectors there, AV and Malwarebytes, etc.
does the RADIO work on other PCs' be like 1st step
Apr 15, 2017 | HP iPAQ H2215 Pocket PC
Bluetooth problem
often i find that programs are to blame for using lots of memory. a hard reset generally closes most of them but i use ClearTemp to remove the registry dregs and unused shortcuts. http://www.pda-ppc.com/download/utilities/content/cleartemp.html hope that helps!
Jul 05, 2006 | HP iPAQ H2210 Pocket PC
HP HX2110 wireless connection
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
HP iPAQ H5555 Pocket PC Logo
224 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
