Question about Kodak EasyShare DX6440 Digital Camera
Start and die
When I turn on my Kodak EasyShare DX6440, The green light and "Reading memory card" splash screen appear, then the camera shuts off. When I change batteries, the splash screen appears and then it tells me that the date and time have been reset. I set the date and time, press continue, and then the green light goes out and the camera shuts off. The lens never came out. Multiple sets of different batteries have been tried, and now the splash screen appears for a shorter time before shutting dow. Is it time for a new camera? No difference when taking memory card out and starting up. We cleaned the battery terminals in the camera and batteries with an eraser, no change.
I have the same/similar problem. I could hear the camera attempting to extend the lens. Camera shut down after timeout.
Disassembled camera & found two teeth missing from plastic gear in gearbox attached to lens motor. Don't know yet if part(s) are available.
Camera had light use. Patheticly short life & that Kodak didn't use stronger nylon gears. Bought a barely use Kodak P880 recently, & the autofocus died shortly after. Web search showed others had same failure. I'll never buy another Kodak camera.
Posted on Jan 05, 2008
    Genius:
  • 2,985 Answers
Could be time for a new camera But check out Kodak Support first. It has been said that cameras in a certain price band[any make/model] are to be considered as disposable -like toasters and kettles I guess.
Posted on Aug 23, 2007
I purchased a 4 GB SDHC card for my kodak easy share dx6440. The camera keeps rejecting it because 'it is not formatted'. I formated it and it still does not read it. is the DX6440 limited to SD 2GB? ...
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Nov 09, 2010 | Kodak EasyShare DX6440 Digital Camera
MY EASYSHARE DX6440 SHUTS DOWN BY ITS SELF OR DOES NOT EVEN COME ON
Make sure that you are using a fully charged battery and of course the recommended battery for your camera such as 2 AA lithium battery or Ni-mh battery. If you already done with all this thing it time to contact Kodak at 1 800 235 6325 ext 12 and send your camera for repair
Feb 04, 2010 | Kodak EasyShare DX6440 Digital Camera
Battery will not charge
The dock can only charge KODAK rechargeble batteries.
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Jan 01, 2010 | Kodak EasyShare DX6440 Digital Camera
DX6440 internal memory. cord misplaced that came
I understand your quarry as you misplaced the U-4 USB cord used for connecting the camera with the computer.
KODAK no longer carries this item for sales. I suggest that you use a card reader instead. A card reader can be purchased in any store carrying technical equipment.
Dec 11, 2009 | Kodak EasyShare C743 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
  • remove the battery and the memory card
  • clean the metal copper on the battery
  • power on the camera without the memory card
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
Sep 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
The camera shuts down soon after starting. Turn camera on green light flashes. Screen says reading internal or memory card. Reset time date excetra. Screen goes black. Lens does not retract.
have same camera haen t had that prob sound s like weak batteries go into menu an dsee what its set at and reprogram it to what you want mine never came with the docking station try withou tand new batteries i use rechargable batteries with nicad batteries holds a charge longer
Aug 10, 2009 | Kodak EasyShare DX4330 Digital Camera
Kodak dx6440 wont power up lens wont and retract
I have the same/similar problem. I could hear the camera attempting to retract the lens. Camera shut down after timeout.
Sep 20, 2007 | Kodak EasyShare DX6440 Digital Camera
Camera lens will not open
Lens motor shot- contact Kodak repair price likely to be well on the way to a new camera
Jul 31, 2007 | Kodak EasyShare DX6440 Digital Camera
Stuck :(
My Kodak DX6440 did the same thing. After sending it to Kodak's third-party repair (as per Kodak), they called to say it was not fix-able. Kodak's response was "No parts available" and offered 10% off list price of a refurbished camera. ...Big sports ...Way to keep customer loyalty If you choose Kodak, the cameras are good but buy them knowing they are a disposable item. BK
Jan 22, 2007 | Kodak EasyShare DX6440 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
159 people viewed this question
Top Kodak Cameras Experts
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
