Question about Maytag Neptune FAV6800AW Top Load Washer
Operator manual I bought a used Neptune TL but I cannot figure out how to work it. Where can I get an operators manual. Also, how long is the normal wash cycle?
  • Anonymous Aug 09, 2008
    plugged stand pipe, how to fix it
Maytag Neptune TL
The TL neptune has a small shock absorber on the middle left hand corner behind the front panel. it uses a small wiring clip that could be loose, with a type of inertia switch.
A common issue I've encountered with this machine is underloading. The snubber and springs allow a fair amount of movement. Don't do a few simple items or mixed load in this machine.
If these don't seem to help, let us know.
Nov 04, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
I NEED A OPERATING MANUAL FOR THE NEPTUNE TL FAV 6800AWW
Here is the Service Manual link on this site. You can also pull from servicematters.com.
It covers the FAV6800AW and FAV9800AW it also has the Use and Care guide.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
237 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
