Question about Champion 24 in. UH-150B Built-in Dishwasher
My model Num. is TUW - 70
Shocks me when I touch it.
  • 63 Answers
It indicate there is a live ac leakage on the chassis.it is very dangerous if you don't have any electric knowledge.don't touch it again.switch off the main supply and contact the service technician for help.
Posted on Aug 22, 2007
Just replaced my front shocks last week, but when jacking up rear tires, front shocks dropped to touching the tires again, any others problems?
Are these air shocks? If they are, then the extra weight on the front wheels can push air past the "O" ring in the inlet air fitting.
Nov 09, 2016 | Cars & Trucks
Tip
How to avoid electrical fatal shocks?
Always keep in mind that if electricity is passed through our brain or upper portion of body where hearts & lungs are affected the electrical shock is likely to be fatal. To avoid electrical shocks and fatal shocks pl do following: 1. Don't touch electrical device or leaky cable with wet hands
2. Before doing any electrical job (even ironing) use clear hill chappal/shoe or stand on any insulator like rubber mat etc. 3. Always presume that any metalic body or cabinet or exposed metal part of an electrical device may give you shock and keep you ready with preventive measure as told above. 4. Switch off device and remove power cable wherever possible before opening/trouble shooting of electrical gadget. 4. The most important: if anybody gets a shock don't touch him/her with your hands. Just use your leg to disconnect him from electrical system. Otherwise electricity will pass through your heart making you lethal shock. 5. As neutral of a power plant is put into earth, the supply line has a tendency to close the circuit to earth through a load (conductor). Don't give any chance to make that 'load' with your body. So never touch live wire or insulate your body to stpo flow of electricity to the ground/earth and remember not to allow passing of electricity through upper part of body. 6. Don't do any electrical job after taking bath. Wet body gets very low resistance and helps in passing high amount of current during contact with live wire. Higher current through body means more danger for life. These small tips will protect you & your family members from any lethal shock. Pl teach this others also. Gautam Kr. mandal, Electrical Engineer, Durgapur
on Jan 19, 2010 | Kitchen Appliances - Others
Kenwood kmix shocked me when i touched the body ...
Stop using it. If the insulation on the power cord is cracked, cut, or bare, you are getting a short from a wire being exposed to the mixers body. This could cause a Fire and/or injure you directly. The source needs to found by a technician and repaired.
Mar 24, 2014 | Food Mixers
Dryer electrical shock
first thing unplug machine and have electrical outlet checked for proper wiring. This is a safety hazard. you can buy a tool for about $5 to check them.
https://en.wikipedia.org/wiki/Receptacle_tester
if it passes this test then there is a wiring issue in the machine. Were you touching anything else metal when shocked?
if it fails, get a professional electrician to check and repair the wiring. Do NOT use any faulty outlet as they can be dangerous.
Stay Safe.
Jun 14, 2013 | Maytag Dryers
Shock from shure green bullet when touching microphone stand
Are you also using a guitar at the same time? If so, your guitar amp has a serious safety problem. Do NOT user your guitar amp until you get it fixed. This is VERY serious.
Jan 21, 2013 | Shure Audio Players & Recorders
What causes my pc to shock nd wats d solution
If you are getting shocked every time you touch your laptop then its because your building of static electricity from your environment. It's just physics and touching anything metal, like screws on the laptop, will discharge it.
Jul 12, 2012 | Computers & Internet
Dryer stop working then start shocking you when touch
The first thing you need to do is turn the breaker off to the dryer , that way you don't risk shock trying to unplug it. The next step is to locate where the wire is arcing over, I would start at where the plug comes into the dryer and move on from there. Thats a very dangerous situation, be careful and good luck
May 27, 2012 | Whirlpool Dryers
Shock absorber of bajaj pulsar 150 is touching wheel. it is working gud with single rider but not with two on board.
hi buddy can you tihgten the springs on the shock as the shock doesnt support the weight it just balances the up and down forces
Dec 02, 2009 | 2005 Bajaj Pulsar 150
When I screw cord to dryer it will shock when I touch
yes its normal,,,,you dont touch them after you hook it up they will shock you
Jan 26, 2009 | GE DPGT750GC Gas Dryer
Shock Nipple Touches Pipe
Mine went the other way touched the frame. The pipe got tweaked a hair when I hit a stump without the Hyde it would have been toast. I added some washers to the upper mount and foward silencer mount to space it off the frame worked fine.,,,
Nov 10, 2008 | 2005 Gas Gas MC 250
Champion 24 in. UH-150B Built-in Dishwasher Logo
217 people viewed this question
Top Champion Dishwashers Experts
bengsoon Neo
Jude24
Trevor Turner
Are you a Champion Dishwasher Expert? Answer questions, earn points and help others
