posted by wb909 on Aug 22, 2007
Oven temp is out of range(+500F)
ERROR.
Oven gets too hot to cook buscuits.
Best Solution
posted on Aug 23, 2007
WB, Your thermostat is shot and must be replaced. The most difficult part of this job is locating one to replace it with.
Have the complete Model and Serial number handy...
First, try locally. Call a local Commercial Kitchen repair/parts house. Surely theres one nearby, they work on all McDonalds, Wendy's, Restaraunts, etc... cooking equipment.
Second, contact the manufacturer;
Star Manufacturing International, Inc.
10 Sunnen Drive
St. Louis, MO 63143-3800
Phone
(314) 781-2777
(800) 264-7827
Fax
(800) 264-6666
After you have it, SHUT OFF THE POWER AT THE BREAKER!!! Now try to turn the unit on to VERIFY you have no power. Then remove the t'stat knob. Now remove the screws holding the control panel in place. Tilt the control panel out toward you. Now you can see the t'stat and see how the sensor bulb is routed. (HINT: Take a piece of paper and draw the back side of the t'stat's wire connection locations and wire colors/numbers, BEFORE removing anything.) Remove the wires and the t'stat and route/wire the new one the same way.
Another tip; Be extremely careful with the sensor bulbs capillary tube (the small tube connecting the bulb to the t'stat). NO 90 DEGREE BENDS ALLOWED! It is a hollow tube, if it's piched/kinked you can throw it in the trash and buy yourself a new one. (It came packaged as a coil for a reason) As you uncoil it, go slow and easy.
10 Sunnen Drive
Phone
(314) 781-2777
(800) 264-7827
Fax
(800) 264-6666
Comment by SolutionGuy, posted on Aug 26, 2007
Can anyone explain why my detailed diagnosis, manufacturer information and repair procedures were "Not Helpful"? This is really making me reconsider helping you people for free.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 07, 2008
if you are using the control panel to operate the oven try it in the Manuel mold (open the door under the control board) and set the
t-stat to the cooking temp .if it cooks ok (you have to time it your self )the probe will be the problem,if it over heats i would think
you have stuck contactor
w tech
w tech
Suggest a new solution for this problem
Post a New problem for Lang Manufacturing EHS-APM Electric
Email this problem
Email this problem
Can you Help with these Ovens problems?
Lang Manufacturing EHS-APM Electric Oven
TIMING ERROR
TIMING ERROR
good evening i work for burger... Answer This...
Repair Service
Find Oven Repairman Near You:
