Question about Texas Instruments TI 880 Matrix Printer
Does not print completely
I am replacing an existing printer, which is hooked up to the pc using the Generic/Text only driver. I print jobs to it from my in house UCS computer system. When printing a document, it prints 2/3 of the page and then just stops. There is a BEEP about 10 seconds into the job and the error light is lit. What prints is correct, but i do not get the entire docuument. I have no manual, so do not know if this is just a setup problem. I have tried changing port settings, and have changed the LPI, but same situation exists.
  • 661 Answers
Sounds like the printer is not set up correctly, you need to check the paper size and positioning to ensure this printer is set properly, check online for a manual as most manuals can be found online
Posted on Aug 22, 2007
  • Gareth Cockram
    Gareth Cockram Aug 22, 2007
    I mean the settings embedded in the printer not the settings on the driver, These Dot matrix printers are a little bit trickey to get set up right, so don't be afraid to tinker with it.
The printer is not printing the last line of my text on a page. What can I do?
Its a problem on the HP Software itself. Most issues exist in MS OFFICE printing.
Work around:
Just try adding a generic printer on printers and faxes like Deskjet 640c > Try to print using that driver and it should work.
However if you want to undergo further troubleshooting with Printer software,
Please contact 1-800-274-6836 (HP INVENT)
Feb 14, 2010 | HP Photosmart C6280 Printer
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
"Generic / Text Only" driver printer and cyrillic
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Aug 05, 2008 | Epson TM-U220 Matrix Printer
I am trying to hook my printer up to my new computer and the disk I have is not working. i do not have a cd for microline 590 elite dot matrix drivers
The drivers should be on the company website, if these are not working for you the generic text driver in Windows will work for text only printing. If you do graphics or formatted invoices, etc. on the printer Epson and Okidata both make pretty generic print drivers that should work for a microline printer.
Jul 31, 2008 | OKI MICROLINE 591 Matrix Printer
Printer Clicking
What kind of printing job are you trying to do?
Jun 11, 2008 | Zebra LP 2844 Thermal Printer
Samsung STP100 Thermal Printer installation
when you have installed the generic driver you must set up the port speed and parity bit settings to mach your printer
turn on the printer while holding "feed" and it will tell you what baud rate it is set to.
Mar 14, 2008 | Computers & Internet
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Prints black on test page, but not when a job is sent to the printer
make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Oct 18, 2007 | Canon BubbleJet i560 InkJet Printer
136 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
