Question about Hitachi 50UX57B 50" Rear Projection Television
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Picture will be good for between a few minutes and an hour. Then it goes bad. Sounds still comes in. When picture goes bad, if I turn off tv for a few minutes, it will be good for a few minutes. Sometimes, if I turn ift off for a few hours, it behaves again, sometimes, problem is still there
It is a Hitachi ultravision projection tv.
the manual says
60SX3B/4K 50SX5P 50U14B/15K
The remote says
Hitachi Genius remote CLU-850GR
  • sfrank962 Apr 01, 2009
    After TV is on for an hour or so, the picture will go out, The sound stays on. 50UX19k What is the componet that is going out? Thx Steve
  • Hitachi Master
  • 10,543 Answers
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Jun 27, 2017
5 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: scrolling lines in the picture
The capacitors in the sweep supply and maybe in the main power supply are starting to dry up. Your going to need to get a tech to go over the boards and search out the dryed capacitors. It will take some time and maybe a bit costly. May want to think maybe about a new set? Good Luck
Posted on Aug 14, 2006
SOURCE: Hitachi clu 615mp
I had this same problem. To fix we unplugged it for a while, plugged it back in and it worked! Good luck!
Posted on Jan 15, 2008
video-tek
  • 150 Answers
SOURCE: Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Posted on Jun 05, 2009
  • 1335 Answers
SOURCE: I have a Hitachi VCR+ remote for my projection TV
Which model Projection TV do you have?
Posted on May 10, 2010
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Jan 11, 2010 | Hitachi Televison & Video
Picture is fuzzy for the first few mins after turning on
This may be an issue with your color wheel where it isn't spinning up to speed at first but finally does after the 2 - 10 minutes. Fairly common in DLP TV's.
This could be fixed by a qualified Hitachi Servicer.
Blessings,
A/V Media Tech Guy
Nov 21, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
50UX18B Hitachi Projection TV
Good Day, monarchdr272;
Sounds like you may have a bad comb filter. Yes things can be repaired. Good Luck, big IRISH.
Aug 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Fuzzy double overlapping images.
Good Day, alsharp;
I am very sorry about the condition of your wife, I hope she recovers totally and my prayers are with you, your wife and family.
Do not turn TV on, the problem may get worse to the point where the TV may go DOA.
It sounds like you have some poor connections on the TV's convergence IC's. Since, you say that you are handy you maybe able to fix this yourself. If you own a good soldering station / pencil.
The convergence IC's will be located on the right hand side of the TV, looking from the back. They will be attached to a large silver device (heat sink). The IC's have 16 pins on each one, there 2 of them, side by side. Remove old solder and apply new.
I hope this was helpful. E-mail me at mmrkcar@yahoo.com for more info if you need it.
God Bless, big IRISH.
Jul 30, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53UDX10B 53 in.
Good Day, hazzletp;
You may have a bad comb filter or one of the CRT's (picture tubes)(cathod ray tube), are going bad. Call an Authorized Service Center and have them come to your home and give you a written estimate b4 repair. Cost AVG $550.00, if CRT is bad go shopping.
Jul 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Rear projection tv
Sounds like your Crt's are going bad
Dec 10, 2007 | GE 46GW947 46" Rear Projection Television
Scrolling lines in the picture
Aug 14, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
