E4 fairland air conditioner - Heating & Cooling
bobotfel
  • 236 Answers
SOURCE: WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Posted on Jan 13, 2008
SOURCE: air conditioner
you want me to tell you how we fixed the problem, well seen as your add says free solutions, and then there is a charge, I will tell you how we fixed our Air Contioner probkem, when you forward me your credit card details and for a small fee we will give you the imformation you have asked for...
Posted on Apr 25, 2008
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
hvac1960
  • 2133 Answers
SOURCE: E4 code on lcd dont
E-4 means short of gas. Find leak and arrest. And then vacuum, recharge gas.
Posted on Jan 06, 2011
rockmeister
  • 2047 Answers
SOURCE: FAIRLAND AIR CONDITIONER MODEL KFR-36GW/L
When indoor air conditioners display LI on screen and therefore doesnt function well simply means the voltage which the unit has been supplied is low and therefore cannot power the unit.
LI simply means Low Input which means the current supplied is low. Simply purchase an automatic voltage regulator for the unit preferably one from 3000watts upwards.
Try this and get back to me.
Hope this solution has been helpful?
Posted on Feb 17, 2011
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
LED on Air conditoner showing E4. Also ice on outside unit, even though outside temp. in the 80sF (I am in Bermuda). No codes given in instruction manual - those found on web written in non-English !
If the air conditioner is the ryyd amerikool the e4 is OVERHEATING COMPRESSOR wants freon air, whether it is another brand might be a change of electrical phases, but send the best brand of air conditioner most definitely.
Aug 08, 2011 | Heating & Cooling
I have a fairland refrigerated air cond
I am delighted for you but what is the problem?
Mar 06, 2011 | Heating & Cooling
Fairland aircon error code E5 what is wrong
E-5 Outdoor activation of compressor over heatprotection or motor lock.
Check out door fan motor mechanism locked, replace motor. If less rpm replace capacitor. If condenser coil dusty, clean it. If no gas/short of gas, do leak test and rectify. Thanks.
Feb 08, 2011 | Heating & Cooling
E4 code on lcd dont cool at that pont on fairland airconditioner
Jan 05, 2011 | Heating & Cooling
E4 error on Yamatsu S-24H air conditioner ?
E4Fault indoor coil sensor (open or closed). Replace it.
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
Jul 12, 2009 | GE APH10AA Air Conditioner
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
455 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
