Question about Samsung SF-3100 Plain Paper Inkjet Fax
Copy problem My problem is that whenever l send a fax, it goes into 2 pages at the other end and also whenever l make a copy with the machine, it starts the page from the middle of the page.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
ONE OF THE DOCUMENT SENSOR IS FAULTY OR DIRTY AND IS NOT RESPONDING CLEAN/REPLACE , PROBLEM WILL BE RESOLVED
Posted on Sep 23, 2007
SOURCE:
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Changing forwading Fax ID address from fax Canon JX200
This information appears at the top of each document you send.
1 Press [Menu].
2 Use [{] or [}] to scroll through the menus and select <DATA REGISTRATION>, then press [Start/Copy] twice. The LCD displays <DATE & TIME>.
3 Use [{] or [}] to select <UNIT TELEPHONE #>, then press [Start/Copy].
4 Enter your fax number (up to 20 digits) using the numeric buttons, then press [Start/Copy] twice (see page 9).
You can enter a space to make your number easier to read.
5 Enter your name (up to 24 letters) using the numeric buttons, then press [Start/Copy] (see page 9).
6 Press [Stop].
Registration ends and the fax returns to standby mode.
Nov 19, 2011 | Office Equipment & Supplies
Changin forwarding address from my fax machine
I don't know this exactly machine type.
Please check this extended manual:
http://pdf.superwarehouse.com/specs/Canon_1735B002AA_manual.pdf
Maybe you can get your answer here.
Nov 19, 2011 | Canon FAX-JX200
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Two vertical lines appear on faxed out pages
HP actually provides a service that lets you test your fax machine:
Testing Your HP Fax Machine
See if this helps. Good luck.
Oct 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Sendidng a fax
I have been sending and receiving faxes for over a year on my Lexmark X6100 printer. Now whenever I try to send a fax it will say it is sending the pages but then waits for a redial. After doing the same thing a second time it will print out "remote fax error"
Aug 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Sending and Copying Problem
THE SCANNER NEEDS CLEANING HAPPY FAXING OMNIPRESENT
Mar 27, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Samsung SF-3100 Plain Paper Inkjet Fax Logo
41 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
