Tasco Galaxsee 46114375  Telescope
Problem for Tasco Galaxsee 46114375 (375 x 114mm) Telescope
The image is upside down
By learnl8 on Mar 24, 2009
the image is upside down in my tasco galaxseer. Please help.
Comments:
Mar 26, 2009
- Thank you.
Solution #1
posted on Mar 25, 2009
Not Rated)
phjore
Rank: Apprentice
Rating: 100%, 1 votes
This sounds like a name for an astronomical telescope. I do not own/may have not seen one, but anyway here goes.
Terrestial images do/will appear upside down. This is normal. Just to add to the confusion some telescopes LEFT and RIGHT can be reversed.
First a few Q's & A's
Can you use different eyepieces?
If 'yes' then what is the diameter* where it enters the scope drawtube/foucuser? (the most popular size is 1.25inch the other is .965inch).
You can purchase what is called an "image erecting prism". This should solve your problem. These are available as an accessory from on-line astronomical dealers. Sorry, but I do not how much you will pay.
As there are many telescope manufacturers 'out there', prices do vary. I cannot remember whether Tasco have one made under thier name. If it helps Tasco are owned by Celestron.
Good luck and clear skies.
Comments:
Mar 25, 2009
- Sorry, I have just seen an image for 'your' scope. So, it is astronomical telescope. Do you use it for astronomy?
I am concerned as to why you are using an Newtonoian Reflector for terrestial use. (Sorry for sounding insensitive).
You still should be able to use an image erecting prism with it. Double check with the seller before purchasing. Just remember the more accessories you put in the lightpath, (i.e. from the objective/mirror to your chosen eyepiece will degrade the final view of the object in question you are observing/looking at).
Image erecting prisms are normally used with "small" Refracting Telescopes (i.e. a telescope that has a lens rather the mirror).
Was this helpful?
Yes
No
Popular Solutions for Tasco Galaxsee 46114375
Questions and Unsolved Problems for Tasco Galaxsee 46114375
Do you recommend Tasco Galaxsee 46114375 (375 x 114mm) Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
I have no manual and cannot seem to find the correct lense to use and get the scope to focus
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tasco Galaxsee 46114375 ...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
