Question about Asrock P4I45GV R5 Motherboard
Asrock P4i45gv motherboard problem
Dear sir, Last week my system is restart automaticly again & again then i am remove the motherboard & plaste the headsink inthe cpu cooling fan then start my computer cpu fan is running but no display no beep sound please solve this problem & guide to me . thankyou
I am remove the motherboard & plaste the headsink inthe cpu cooling fan then start my computer cpu fan is running but no cpu heet no beep sound
Posted on Feb 26, 2010
    President:
  • 2,961 Answers
It sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Posted on Aug 22, 2007
SOURCE:
Hello, my system has Asrock P4I45GV Motherboard.
your possessor fan dos not properly work or fan casein do not properly instal or your power supply faulty.
Sep 04, 2013 | Asrock P4I45GV R5 Motherboard
I need a sound card of P4i45GV ASrock
sir you can go to asrock official site
http://www.asrock.com/mb/download.asp?Model=P4i45GV%20R5.0&o=XP
May 23, 2011 | Asrock P4I45GV...
Hi, I'm using Asrock P4I45GV R5 Motherboard. but when i attempt to install OS, it shows NTLDR Missing. but HDD is working properly. at the next time when i try to boot from the CD it fails. and i need to...
just go to in bios setup using F2 or del key and change the booting sequence.and set 1 cd-rom 2.hdd
now save and restart system now you are able to boot from cd rom r dvdrom
Apr 10, 2011 | Asrock P4I45GV R5 Motherboard
P4I45GV cannot start when i on the power button but when i disconnect the power socket and then i will connect the power socket i will be start automatically by the next time it will not star
Hello Sir,
I think you have to check the power connections given to your Motherboard, this happens only when there is some kind of wrong power connections to your Motherboard. I have also given you the manual for your Motherboard, might be useful for you when you check the connections
Link for manual
http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Aug 11, 2010 | Asrock P4I45GV R5 Motherboard
I have a asrock p4i45gv motherboard ther is no sound in my system
the drivers are avilable on the manufacturers web site,, here is a direct link to the drivers
Apr 02, 2009 | Asrock P4I45GV R5 Motherboard
Mother all driver
Hi, my Board is Asrock P4i45GV
I have a Ati Radeon 9250 128Mb with the drives
On The : Computers Manegement--> Device maneger--> Other Devices
It show that VideoController need drives
I had put it to update Drive automatical but it doens get any drive
what can I do?
Sep 28, 2008 | Asrock P4I45GV R5 Motherboard
Frequent machine restart
Hi
yes problem because of virus or ram. first you install any good anti virus (nod 32, Kaspersky or BitDefender) if problem contuses replace fan, at last replace ram...
Thanks
May 06, 2008 | Asrock P4I45GV R5 Motherboard
P4i45gv asrock motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Restarting problem
constant restarts are down to a faulty driver or the cmos battery needs replacing, or short the motherboard cmos jumpers and reset the motherboard settings
Jul 25, 2007 | Asrock P4I45GV R5 Motherboard
Asrock P4I45GV R5 Motherboard Logo
289 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
