Question about KitchenAid KAWS850L Dryer
My 10 year old kitchenaid dryer
I'm sorry about coming in here with an old machine problem. My dryer is about 10 years old and does not produce any lint in the filter. Can you suggest anything?
    Novelist:
    Champion:
  • 244 Answers
If its not producing lint then more than likely that it has a hole in a inner pipe and the lint is going inside your drum take the back off with the machine un-plugged and check if lint is inside then clear it out has this can set afire then find were it is coming from u can do this 2ways look for the hole or plug back in and start it if u will notice were it is coming from within a few minutes
Posted on Aug 23, 2007
SOURCE:
Strange tapping noise
forget about using youtube try googling it and see if u can get help? not sure but the compressor has a seal that separates the coolant from the oil and when it goes or starts to leak u may get weird sounds? sorry cannot help more Ive heard clicking sounds before from the compressor but it was usually due to bad relay having to do with the starting process
Feb 19, 2015 | KitchenAid Refrigerators
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
Gas dryer will not produce heat
Have you ever replaced the thermal couple . This is a sure bet . these need to be replaced a bout 5 or 6 yr.s This is not a expensive fix. you may be able to change it your self. DFD
Apr 20, 2009 | Dryers
We have a 10 year old KitchenAid washing machine and tonight after it filled with water instead of working properly it made a wierd noise and didn't agitate. How much would it cost for someone to come and...
The KitchenAid is an excellent washing machine and I would recommend keeping it going as long as possible. The most probable cause is a broken motor couple and the cost to repair is around $100
http://tclaundryrepair.com/home
Feb 19, 2009 | KitchenAid KAWS700L Top Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
KitchenAid KAWS850L Dryer Logo
123 people viewed this question
Top KitchenAid Dryers Experts
Virgil Watts
Marvin
Marvin
Ekse
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
