Question about Nokia N70 Cellular Phone
Not able to acces gprs as well as mms
Hi i have a nokia N70 my problem is i m not able to acces GPRS on my handset as well as i m not able to sent or recive MMS.. i have all the setings of GPRS as wll as MMS to.. tellme what should i do for this problem help me out this problem..
  • chunnu Aug 22, 2007
    yes i do all solutions but its not working and all setings are ok and errow message show:- no gateway reply now what should i do
    Sergeant:
  • 452 Answers
If you are unable to use the gprs service and mms service ..for that you have to get the services activated from the servcie provider.than you have to get the settings form the service provider once you get the activation and settings you would be definitly able to use the service if it is not working even after that than you have to check whether you are getting the proper gprs signals in your area or not
Posted on Oct 18, 2007
  • 36 Answers
First of all, check ur GPRS/MMS service is enabled or not by service provider. If yes, receive GPRS and MMS settings from ur service provider by SMS or mannually. If problem not over, send me details msg/error on ur device. [email protected]
Posted on Aug 22, 2007
SOURCE:
It's on my Smart No. 09199634778. It received messages from Smart that I have MMS pictures. Can they be shown here?
Yes sir,to retrieve MMS data,you should activate you MMS/GPRS by configuring the settings of your network provider or Smart provider.
Here's how to Activate the your MMS/GPRS
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333′
To activate SMART MMS:
Key in "MMS ON" and send to "333′
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
Hope this solution helps you. Thank you for visiting FixYa..
Jul 24, 2011 | Nokia N70 Smartphone
Tip
Gprs & MMs settings for india mobile networks 1
&gt;AIRTEL <span> </span> You can give a request for activation of this service by dialing 121, <span> </span> <span> </span>you can also send in your requests through email [email protected] <span> </span> <span> </span>or SMS at 121 respectively and our customer care executive will help you <span> </span> <span> </span>with your handsets MMS settings. . MANUAL SETTINGS <br /> <span> </span> #AccountName:- AIRTEL MMS <br /> <span> </span> #Server:- http://100.1.201.171:10021/mmsc <br /> <span> </span> #Proxy:- 100.1.201.172 <br /> <span> </span> #Proxy Port:- 8799...**** <span> </span> <br /> <span> </span>&gt;AIRTEL NOP GPRS SETTING <br /> <span> </span> <span> </span>#Account Name - Nop <span> </span> <span> </span>#Homepage - http://google.com/xhtml <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Proxy and Server Adress - 100.1.200.99 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data bearer - GPRS or Packet Data <br /> <span> </span>#Acces Point Name - airtelwap.com <span> </span> <span> </span>#Authentication Type - Normal <br /> <br /> <br /> <span> </span>&gt;AIRTEL LIVE GPRS SETTING <span> </span> <span> </span> <span> </span>#Account Name - Airtel live <br /> <span> </span>#Homepage -http://live.airTelworld.com <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes. <br /> <span> </span>#Proxy and Server Adress - 100.1.200.99 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data bearer - GPRS or Packet Data. <br /> <span> </span>#Acces Point Name - airtelfun.com <span> </span> <span> </span>#Authentication Type - Normal <br /> <span> </span> <br /> <span> </span>&gt;RELIANCE .GPRS & MMS <span> </span> You can get GPRS settings on your mobile <span> </span> When you insert your New Reliance Mobile SIM Card into the handset you will receive an SMS <span> </span> Trigger (within 48 hrs) with GPRS settings. You just have to click on the message and <span> </span> SAVE the settings to access R World. <span> </span> SMS &lt;all&gt; to 55100 <span> </span> You can also get the GPRS settings from R-Menu. <span> </span> You just have to click on R-Menu and then go to get settings. Then select GPRS settings. <br /> &gt;BPL GPRS SETTING <span> </span>#Account Name - Bpl WAP <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://wap.mizone.bplmobile.com <br /> <span> </span>#Proxy and Server address - 10.0.0.10 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name - mizone <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal
on Jan 11, 2011 | Cell Phones
Panu ako makakapag internet sa fone??? nagtry aq kea lang may kailangan pa atang configuration... manual daw??
Ano po bang model ang gamit ninyo? maaari po kayo mag internet sa phone sa papapagitan ng wi-fi o GPRS. Kung may wi-fi po ang phone ninyo,i-on lang po ito at pwede na kayo dumiretso sa browser. kung wala namang wi-fi ang phone ninyo eh kailangang ma-activate ang GPRS ninyo upang makapag internet po kayo.
sa pag activate ng GPRS, kung GLOBE po ang gamit ninyo eh automatic na pong matatanggap ang configuration settings ng nasabing GPRS,i-save lang po ito at ang may code pong hinihingi,ipasok lang po ang 1234 at pagkatapos i-save eh pwede napo kayong mag internet,basta may load po ang sim ninyo ok na po ito.
In SMART :
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in "GPRS ON" and send to "333?
Key in "MMS ON" and send to "333?
Note :
In SUN CELLULAR
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS to 1200.
2. Manually configure your handset : CLICK MO AKO
Sana po makatungong...
Jun 23, 2011 | Cell Phones
I cant activate my MMS
Title: MMS settings
For Hotlink GPRS Activation
Press *133# to activate your Gprs & MMS
For the setting
1. SMS "GPRS "BRAND" "MODEL" and sent to 22333 example "gprs nokia n70"
2. SMS "MMS "BRAND" "MODEL" and sent to 22333 example "mms nokia n70"
Manual WAP Settings
? On Desk, tab Control Panel -> Internet setup. (or similar)
? Tab New access pt. and tab No, then tab Next and key in the following:
Connection name: Maxis GPRS / Maxis 3G
Data bearer: GPRS
? Tab Next
Network type: IPv4
Auto-retrieve access point: (Unchecked)
Access point: net / unet
? Tab Next and key in the following.
Prompt password at every login: (Unchecked)
Username: maxis
Password: wap
? Tab Next then tab Finish and OK to complete the setup.
? Homepage: http://wap.maxis.com.my/wml/index.wml
? Session Mode: Permanent
? IP adress: 202.075.133.049
? Login Type: Automatic,
? Authentication Type: Normal
MMS Settings
May 12, 2011 | Computers & Internet
How to activate the gprs of n5310 xpress musi, using my smart buddy sim
Note :
Feb 15, 2011 | Computers & Internet
I activeted gprs & mms settingin but my nokia 6300 mms not sent & not receive mms, pls help me to sent & receive mms on my nokia 6300. & i use bsnl pri-paid card
Please activate any GPRS and MMS plan and selected GPRS and MMS settings as default. Also check with your service provider which all providers you can send and receive mms because some service providers do not allow to send mms to other service providers like Aircel.
May 24, 2010 | Nokia 6300 Cell Phone
My 3110 wont let me send pictures
hi there,
you can follow the procedure inserted below hope it will help you to solved your problem...
any further question you can log on this site,,
http://www.yugatech.com/ringtones/tips-tricks/activating-your-smart-mms-gprs/
Here’s a quick tip on how to activate your phone’s Smart MMS and Smart GPRS settings if you’re with the Smart network:
Example: If you have a Nokia 6230, that’s “SET MMS N6230
Key in “GPRS ON” and send to “333′
Key in “MMS ON” and send to “333′
Note :
The configuration settings will be sent to your phone. You will need to select “Save All” to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Feb 16, 2009 | Nokia 1110 Cellular Phone
Applicable to nokia 6600?
Yes sir.. its applicable to this handset also. I think almost every nokia phone has similar kind of settings.
Nov 29, 2008 | Nokia 6600
GPRS settings...
There are different solutions to this problem:
1) You can get the GPRS settings from any of your friends who is using N70 handset.
2) Contact your service provider to get the GPRS settings.
3) Go to below mentioned site, you will get an idea how to set your GPRS settings
http://customerservice.globe.com.ph/bmw/servlet/ViewItem?id=97
Nov 28, 2008 | Nokia N70 Cellular Phone
GPRS
i dont konow how to open my gprs
Dec 20, 2007 | Sony Ericsson T630
Nokia N70 Cellular Phone Logo
170 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
