Question about Belkin (A3L85014BLS24)
Belkin network failure
We have a belkin key to connect to a wi-fi network and it keeps falling off the network, sometimes disconnecting completely and we have had to reinstall. Whats happening? We have two other computers on the same network which are connected via different network keys and we have no problems.
  • 12,061 Answers
Try disabling XP's zero config service sometimes it causes exactly wh, I have foud a link below to describe how to do it.t ya saying tech.ifelix.net/2000.html
Posted on Aug 22, 2007
How to set up Belkin 300 wi fi extender
Follow our step-by-step guide to Set-Up Belkin Router Wi-Fi Range Extender Call 1 800 335 8177 How To Set Up Belkin Router Wi Fi Range Extender. We are available to fix issues and errors of our customers 24*7 with in a span of time.
Call us: 1-800-335-8177 (Toll-Free)
Sep 28, 2016 | Belkin Components Belkin - Ieee 802.11n...
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
N300 Daul-Band Wi-FI Range Extender
call time warner cable and they can help you set it up for free.
Jun 11, 2014 | Belkin Components Belkin - F9K1111 -...
I am trying to change the ssid to something more sensible (i.e., "myname network") as there are numerous wifi networks locally. But when I "apply changes" the update appears to be working for the duration...
You are changing the ssid so if you are using wireless you will lose the wi fi connection and would need to disconnect wi fi and then search wi fi networks for the new ssid and then connect to it.
you could connect by ethernet cable till you get it right .
Nov 07, 2017 | Belkin N600 DB Wireless Dual Band N Router
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Password
Ok... There are tree things you need to know about securing your WI-FI network.
1: Each computer needs to have "permision" to access your WI-FI network.
2: The "Passphrase" and the "Key" are not the same thing. The "Passphrase" doesn't always work. But the "Key" should. (MACs will need the "key")
3: Some WI-FI equipment is "too old" to use 128 bit WEP or WPA.
(I don't think this aplies to your problem)
Nov 22, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (A3L85014BLS24) Logo
201 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
