Question about NEC 1560V+ 15" Flat Panel LCD Monitor
Mounting a NEC MultiSync LCD 1560
How do I mount this monitor on a wall?
    President:
  • 1,114 Answers
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
SOURCE:
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
Hi, the side mounted USB ports on my NEC Multisync 90gx2 monitor do not work
The USB ports on the LCD is a USB hub. To use these ports you have to connect the input of the USB Hub of the LCD to one of the USB ports of the computer through a USB cable. You need a simple USB Printer Cable, which is easily available from any Computer Accessories store. Below is the picture of the cable. The normal USB plug (on the left) goes to the USB Post of the PC and the square one at the right should be connected to the LCD.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | NEC-Mitsubishi MultiSync 90GX2 (Black) 19"...
Nec multisync 1525x need user manual. annoying menu keeps poping up on screen. any ideas ?
Here is the link for an Multisync 1525x
http://www.necdisplay.com/cms/documents/UserManuals/l1525Xg.pdf
Feb 25, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC 1560V+ 15" Flat Panel LCD Monitor Logo
482 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
