Question about Xerox Phaser 6100/DN Laser Printer
Colour Printing Colour pictures are printing out green. Have checked all toners and they are not empty. It has a message on it saying replace transfer belt and also imaging unit. Could this be the problem?
  • 661 Answers
YES, Possible faulty / contaminated Transfer system, I would get this serviced, as this is a more complex fix
Posted on Aug 22, 2007
If one of the colour catridge is empty or damaged, willthe printer will not do the printing jobs at all?
This might be the issue.... The paper still has to pass through the magenta even if its not used but being empty it might not register the toner hence not allowing you to print at all.
Jun 27, 2016 | HP Officejet 6500A Plus Wireless...
Konica Minolta 1580-MFP how to reset replace low toner message printer ?
  • Purchase OEM toner, toner has chip on it chips say toner case is empty it is empty you replacing the toner will not fix that
May 04, 2016 | Konica Minolta Office Equipment & Supplies
Toner empty error message
my dear you chek toner and change toner tenk
Jul 08, 2015 | Xerox WorkCentre 3119 Laser Printer
HP color laserjet cp2025 will not print. Help.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
I'm getting white streaks (weak printing) on my ricoh c420dn. It happens only with yellow and cyan colors as you can see in my orkut (public) profile...
There are many possible causes. You'll have to do a bit of detective work to find your particular problem. you're either getting unwanted toner, or the printing process is being interrupted.
The photosensitive drum can get a mark or a spot or even a damaged area. This usually presents as a regular area which repeats, going down the print, rather than a streak It may be possible to clean the drum with a soft tissue -- perhaps with the addition of a little Isopropyl alcohol. If you have a replacement drum, try that. In most cases the drum is part of the cartridge, but not always.
Loose toner in the system.
If your drum is leaking, or you've spilled some toner inside the printer (perhaps after shaking the cartridge to get more life out of it) the excess toner may cling to the paper in streaks and get fused onto it. The cure is a good vacuum clean of the insides.
Sometimes a small corner of a sheet of paper (or similar) can get caught in the workings of the printer, This can obscure part of the optical (especially with LED printers) and cause a blank streak in the printing. Dust and toner on the LED head can cause similar problems and fuzzy printing. Tissue and alcohol again!
Jul 18, 2011 | Office Equipment & Supplies
How do I change ink colour for printing on my PC, At present, all printing is in green. I want black.Windows XP Home.
If everything printing out green then one of the ink may be empty please check it and replace the empty ink.
Feb 01, 2010 | Dell Dimension 2400 PC Desktop
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
Xerox Phaser 6100/DN Laser Printer Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
