Question about MSI L730 Notebook
Battery Li-Ion 6 cells, 4800mAh, 65W
Dear All, I do not believe this battery is able to work only 1,5 h! (just internet forum chat, mailing or excell, no video or heavy games) Has anybody idea about it: worth to change - for what type, or how to help it. Thx in advance!
Battery suppliers in my area, CHICAGO
Posted on Apr 14, 2008
    President:
  • 2,961 Answers
Most notebook batteries from new will last about 2 to 2 1/2 hours on the battery, but after about a year you will only get around 40mins to 1 hour. You should have a settings programme built in to reduce the amount the processor works when using low required powered programmes and also the brightness of the screen can be reduced to save power and also turn off the wireless adapter when not in use. I would recommend taking your notebook to a reputable repairer or battery supplier to ensure you get the correct battery that suits your charger
Posted on Aug 22, 2007
SOURCE:
Can i rebuild this battery pack, and if so, can i add more cells
Not recommended. The case would have to be modified to accommodate more cells, the circuit board inside the battery casing may not function properly, and unless you have a commercial dual pulse welder working with Li-ion could ignite. Save time and money and pick up an extended battery such as this one : http://tinyurl.com/pxcpqv9
May 22, 2013 | Toshiba Pa3817u-1brs Laptop Battery -...
Tip
High Quality VGP-BPS13 Battery,Replacement Sony VGP-BPS13 Battery 4800/ 5200/...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Nov 20, 2010 | Computers & Internet
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
Battery specs for IBM T43
Voltage: 10.8 Volts
Capacity: 4400 mAh
Battery Type: Li-ion 6 Cells
Voltage: 10.8 Volts
Capacity: 6600 mAh
Battery Type: Li-ion 9 Cells
Sep 27, 2011 | IBM ThinkPad T40 2373 Notebook
Looking for battery pack replacement for Asus Li-ion A32-W7rating +11.1v 4800mAh
Registered to the side from bellow link.
http://www.sale-battery.com/asus-a32-f3-battery.html
Purchase from the side it will saver.
Hope this helps.
Reply for further information.
May 18, 2011 | ASUS Computers & Internet
Tip
Laptop Battery Common Knowledge You Should Know
There are five common laptop battery knowledge you should knowQ1: What does 3 cell, 6 cell means we said normally? Is it related to the battery capacity?
A1: 3 cell, 6 cell means the battery cell amount in the battery. The more batteries cells, the greater capacity of the battery, and also the longer use time.
Q2: How many kinds of the laptop batteries?
A2: It is mainly divided to nickel-cadmium battery, Ni-H battery, Li-ion battery. They always show as Ni-Cd, Ni-MH, Li. Recent years, a kind of fuel battery appears in laptop field. The present laptop commonly use Li-ion battery, but seldom model still use the obsolete Ni-MH battery, consumers can identify this from the sign on the batteries.
Q3: Why the manufacturers only implement 1 year guarantee policy for the battery?
A3: Li-ion battery working life is very short. Normal Li-ion can only charge 400-600 times. After special improvement battery also can’t exceed more than 800 times, it turns to obsolete after 2 years working life.
Q4: Why do the batteries can’t be use reach to the nominal time which announced by the manufacturers?
A4: The test condition is different. Some manufacturers use 8 cell battery to do test, but supply battery users 6 cell battery, some manufacturers close all the programs, turn down the LCD screen brightness, ban to using high power interface and other measures to test the working life, but it is can’t be reach in the daily life. And some other manufacturers only use the software to do test, but software test may cause error.
Hot laptop batteries on sale:
dell inspiron 1525 battery US $ 56.59
dell inspiron 6000 battery US $ 70.69
dell inspiron 6400 battery US $ 77.90
dell xps m1530 battery US $ 66.18
Q5: What should be take notice for the using and storing of the battery?
A5: Users should pay attention to below points:
1 The battery should be charge full over 8 hours in the beginning charging process to activate the Li-ion battery sufficiently.
2 The battery can not be discharge excessively.
3 It is better not to use the battery when use the AC adapter at the same time.
4 Storing attentive points: The battery should be take out to charge at least once monthly, It is inadvisable to store the battery when the battery is full, it is good to charge only 40% - 50% for the storing purpose, last but not least, the battery should be put in the dry and shade places.
more batteries info via :
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Battery for HP Compaq nx7400
The difference is battery life. So just buy whichever you can afford.
Jan 14, 2009 | HP Compaq nx7400 Notebook
Battery removal asus a6000
This is the model of your battery Asus A6000U - Compatible Replacement Li-ion battery. 14.8V 4800mAh. Equivalent to A42-A3, 90-NA51B2000, 90-NA52B2000, 70-NDK1B2001 -- CBI0967A
regarding for removal-you can see at the backside of the LCD,you can remove by pressing the lock to unlock.
Oct 21, 2008 | ASUS A6U Notebook
Open Questions:
See all MSI L730 Notebook Questions
MSI L730 Notebook Logo
118 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
