Is this a diesle engine?
Yes' diesal
Hi, if u got any advise plz give me' couse is my first buy renault and diesal
If it is diesel the black smoke is normal if you give it hell, know it shouldnt do this while driving normal, so maybe you fuel air mix is a lil off.
SOURCE: renault kangoo 1.9 diesel glow plug light comes on
p100d error code is due to fault in EGR Valve.The EGR valve shuts off to when 3000rpm is exceeded.so the EGR Valve needs to be checked and replaced.
Thanks. you can rate this solution and show your appreciation.
SOURCE: renault clio 1-5 dci (2002)
Hi there!
It's very likely a valve stem seal that has split. This will allow oil into the cylinder from the crank gallery.
Off with it's head! I'm afraid.
The only other thing it can be is overfueling - but then it will be sputtering and lagging on acceleration.
You can check which cylinder is affected by removing the plugs and looking for the oily one. They will all need replacing really as it's false economy to do just 1. The seals are cheap. I would get a new cambelt fitted at the same time - as it has to come off anyway.
(If this leads to a solution, please take the time to rate as Fixya! - Thank you)
SOURCE: replace cv boot on a renault kangoo
Did one today, assuming drive shaft removed take off large clip from inner boot slide back joint socket comes away leaving the knuckle joint on the shaft remove 19mm circlip and tap knuckle off spline this allows outer boot to come back - easy enough. Not much tubber to secure new clip over boot though especially with all the grease.
SOURCE: help, need the security code for renault kangoo van
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm the MAKE of CAR it is fitted into.
Renault Kangoo (KC) 1.4 i car bodywork specifications: Renault Kangoo is a minivan with 5 seats and has 4 doors. Dimensions information of car: 3995 mm long, 1827 mm high, 1663 mm wide. Other Renault Kangoo (KC) 1.4 i cars specs: 2600 mm wheelbase, rear track has 1418 mm, front track has 1405 mm, ground clearance - 140 mm. Total car weight is 1155 kg and 1665 kg of maximum weight, cargo capacity (volume) if from 650 to 2600. Tires type for Renault Kangoo (KC) 1.4 i is 165/70 R14 T. Car engine specifications: 1390 cm3 displacement, located front, transverse with in-line cylinders, 75.8 mm bore. Renault Kangoo (KC) 1.4 i has 4 cylinders. More car engine information: 9.5 compression ratio, 77 mm stroke, car has 2 valves per cylinder, distributed injection fuel supply type, engine power 75/5500 hp, engine torque equals 114/4250.
Transmission specifications of Renault Kangoo (KC) 1.4 i wheel drive is front, it has 4 gears of automatic transmission,.
Renault Kangoo (KC) 1.4 i has wheel-rail type of steering. And hydraulic system power steering.
Rear brakes are drum brakes. Front brakes specs: ventilated disc brakes.
Performance Renault Kangoo car data: it takes 17.3 sec. for Renault Kangoo (KC) 1.4 i to get 100 km/h speed. 147 km/h is the max speed. Renault Kangoo gasoline tank has 50 liters capacity. The car consumps 9.5 liters in the city, 6.3 liters on the road.
TMTM
