Question about NetGear WGT624 Wireless Router
Connecting VPN using Netgear 624
I have new Netgear WGT624v3 wireless router, This router work good with internet with goo speed and coverage, but the biggest problem I face is I'm not able to connect to my office using VPN. I read in blogs that the configuring this router to VPN is bit tough, but this still can be done. Can anyone please help me in getting my router configured! This is first time I'm configuring a router and has now idea how to get this done. Thanks and appreciation for any help!
    Problem Solver:
  • 12 Answers
This is no small undertaking. You will first have to decide if you are going to use software or hardware vpn. Software vpn is free and only requires that you install it (the client) on whatever remote system you are using to connect to the 624. I can say that you want to have your internet connection point (DSL modem or Cable modem) set to "bridge" mode. This will pass through all traffic to the netgear directly. Some (like a speedstream 5200 DSL modem) allow this or they have a DMZ feature which will accomplish the same. Either way you want to ensure ALL ports and all traffic are getting to the netgear. Once that is done you simple create a string at both ends that match for your security phrase and an authentication that matches and you should be good. It's really a lot more than what could be provided here. (Several lengthy documents worth) but I can provide you with a useful link that will give you an a-z about VPN and has specific walkthroughs for Netgear users only. http://www.vpncasestudy.com/index.html Hope this helps a little.
Posted on Aug 22, 2007
  • Anonymous Aug 22, 2007
    As a side note: Although you'd have to buy more equipment, hardware VPN is the way to go. It's much more secure and it's much easier to setup. Businesses that use VPN always have hardware at both ends. (Essentially you'd get another VPN router at the other end. They also make notebook based hardware VPN devices. I mention this because with software ANYONE can download the netgear client and use it. Also the software clients require a bit more setup. Either way it's cumbersome to some extent if this is your first router project. That link I gave you will have setup instructions that work well.
SOURCE:
Need to update firmware on netgear wgt 624 v4 router
Hi ckane47,
You can download and read about problems and solutions for this model HERE.
Goo Luck,
And don't forget to leave a rating.
Thanks
Mark
Oct 07, 2009 | NetGear WGT624 Wireless Router
Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Jul 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Cisco vpn will not work with verizon service now after we got a new modem through verizon
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
Jul 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
No wireless
Hello Chantalallie
Is the laptop able to connect to the Internet wirelessly over other networks? (say at a coffee shop or Internet cafe, etc.)
(We want to pin down whether or not the issue is w/ your laptop or w/ the router.)
If the laptop is not functioning wirelessly at all now, make sure that the wireless radio button on your laptop has not been inadvertently placed in the OFF position. Where that button is located varies w/ ea. laptop. If you're not familiar w/ where it is, look closely along the sides and front of your laptop and above the keyboard (below the monitor).
Still on the assumption that your laptop's wireless radio is not working:
(A) Click on START
(B) Click on NETWORK CONNECTIONS
You should see a connection called "Wireless" or something similar.
(C) Check to see if that connection is DISABLED.
(D) If it is, right click on it and choose ENABLE
OK, now we'll await your answers before proceeding as doing so now would necessitate making assumptions regarding your equipment, operating system, etc. that may not be correct.
Thank you,
BJ
Apr 04, 2008 | NetGear WGT624 Wireless Router
Just want your opinion
Standards
  • IEEE 802.11b, IEEE 802.11g, 2.4 GHz
Physical Specifications
  • Dimensions: 8.8 x 6 x 1.2 in (223 x 153 x 31 mm)
  • Weight: 1.2 lbs (.5 kg)
Performance Advantages
  • When used with RangeMax client adapters, delivers the longest range of any wireless technology on the market up to 500,000 square feet of uninterrupted coverage*
  • Maintains video quality up to 10 times the effective speed when at long distances
  • Improves performance of existing legacy 802.11b and 802.11g wireless devices up to 50%
  • Five 10/100 (1 internet, and 4 LAN) ports equipped with auto-sensing technology
  • Data speed of up to 108 Mbps*
Privacy & Parental Control
  • “Trusted user” controls
  • Time-based usage controls
  • Web site logging
  • Remote management
  • URL content filtering
Security
  • Double Firewall
  • Network Address Translation (NAT) to hide PCs & files from outside users
  • Stateful Packet Inspection (SPI) firewall to deny outside requests for personal information
  • Denial of Service (DoS) attack prevention
  • Intrusion Detection and Prevention (IDS)
  • Wired Equivalent Privacy (WEP) 64-bit,128-bit encryption
  • Wi-Fi Protected Access (WPA, Pre-Shared Key)
  • Wireless Access Control (SSID) to identify authorized wireless network devices
  • Supports 2 VPN pass-through tunnels (IPSec, L2TP, PPTP)
  • Exposed Host (DMZ)
  • MAC address authentication
Warranty
  • NETGEAR 1-year warranty
Package Contents
  • RangeMax Wireless Router (WPN824v2)
  • 12V, 1.0A Power Adapter, localized to country of sale
  • Ethernet Cable
  • Vertical Stand
  • Setup Guide, Setup CD Warranty/Support Information Card
this product seems good, but do you need only wifi o do you want also wimax?
Sergio
Mar 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Not able connect to VPN from my new Netgear WGT624v3
Uncheck the "disable SPI firewall" option in the wireless settings for the router.
Aug 20, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
330 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
