Question about Brother DCP-110C All-In-One InkJet Printer
Cannot clean heads
When I turn on my printer an ! comes up and continually says cannot clean heads, printer error, refer to maintenance manual. Not much help there. It did say there may be a DCP mechanical problem, what problem and can I get it fixed.
  • 832 Answers
The printhead is broken. This is the former error 41. You need a new printhead which is very costly. Better buy a new dcp printer and do NOT use thrid party carts. (Refill with dye ink only).
Posted on Sep 09, 2007
  • Mix-it-up
    Mix-it-up Sep 29, 2007
    If the display shows up: unable to clean you have to change the waistinktank.
    See here how to to that:
    You need a new waistinktank as a sparepart. Look for a service dealer on the brother webside who can sell one to you.
Page is coming without printing
heads clogged. run maintenance on menu +head clean up
please do not do it more then two times .refer to manual
2.-no ink: replace
3.-:head gone? time for new printer !
4.-watch tutorials on youtube about trouble shooting
Dec 28, 2014 | Epson LX-300 Matrix Printer
We have a X5650 Lexmark printer. The ink cartridges were both replaced with certified cartridges (parts 36 and 37xl) . When installed the printer does not recognize that the cartridges have ink and...
It could be that the cartridges are not inserted properly in the carrier or just needs cleaning. Try to remove both cartridges from the printer and manually clean the nozzles. You may refer to this article on How to Clean the Print Cartridge Nozzles and Contacts Manually. Then reinsert one cartridge first and close the cover. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try the Clean Cartridge function on the printer by pressing the Setup button -> Maintenance -> Clean Cartridges. It will then print the clean nozzles test page. If error continues, replace the faulty cartridge.
Jan 20, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer says ,"unable to clean refer to users manual",but cannot find any reference to the problem. hope you can help. thanks peter
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 30, 2009 | Brother DCP 115C All-In-One InkJet Printer
Error reading " The type of print head is not correct...
You need to check that you were able to install the genuine Canon cartridge. If it is already genuine, try to do a printer maintenance by cleaning the print head, calibrating and align printhead. You can run this using the printer tools.
Sep 23, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Jun 17, 2009 | Xerox Phaser 8400 Laser Printer
DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
Check me out at
May 04, 2009 | Brother DCP-340CW All-In-One InkJet...
Canon mp600 won't print every line
hi! there if streak came to your printed paper,try to go on maintenance menu.doing this left click crontol panel and then click your priter,on printer left click and click properties then click maintenance,on maintenance click clean,make it several time then click pattern test if this acquired quality print,if theres problem try the deep cleaning observe there are much ink to consume in deep cleaning,don,t try to clean your print head w/c not recommend on your manual,otherwise you will damage your printer head,if still streak bring this to your cannon service center to check printer head status,regads and havw a nice day thank's.
Mar 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
"Refer to Maintenance Manual"
try looking here for a solution and manuals to download.
Hope this helps
Jan 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Ricoh GX3050N printer - not printing...
could be that the heads are blocked !! try to make the maintenance procedure head cleaning and head flushing from the printer or from the pc select the printer and go to the printing preferences and select maintenance and continue from there and try ,if it does nt solve the problem try to clean the head manually with a soft cloth or there are special cloths for the heads .
Sep 19, 2008 | Ricoh Aficio GX3050 GelSprinter
8500 Phaser error 07 010 43: 6975
6975 I know of nothing that references.
I honestly don't know where you could get a manual. Other then try googling "the parts drop" and calling them. Talk to Britt.
Normally that print block is sticky or the cleaning blade is stuck to the print head causing that error.
Aug 07, 2008 | Xerox Phaser 8500/DN Printer
Brother DCP-110C All-In-One InkJet Printer Logo
158 people viewed this question
James Cagle
James Cagle
Jim Keysor
