Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Microsoftpowerpoint.exe virus a virus named as microsoftpowerpoint.exe is in system.my folderoption in the controlpanel is not seen now.i have mcfee virus scan in system.it cannot delete the virus in usbmemory.
  • piexp Dec 07, 2007
    folder optino is not present in control panel.
    command prompt is not working.
    President:
  • 2,961 Answers
You will have to stop the process from executing by either pressing Ctrl,Alt & Del and then looking on the proceses tab and click on it and select end process, turn off system restore then run a virus scan and a third party spyware scan. The other way is to start your pc in safe mode (keep pressing F8 on boot up) so that the virus does not start up and then select start windows in safe mode. When in safe mode turn off system restore so as the virus cannot back itself up and then run a virus and spyware scan. When and if the virus is found, turn on system restore again and press Ctrl,Alt & Del again and see if the process has been removed.
Posted on Aug 22, 2007
SOURCE:
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Pls advise if the following processes running in my Task Manager are viruses or genuine system processes - ccSvcHst.exe; lsass.exe; explorer.exe, winlogon.exe; svchost.exe; wuauclt.exe; jqs.exe;...
ccSvcHst.exe - works to display the GUI (Graphical User Interface) of Norton products, which usually include the Norton Security Suites.
lsass.exe - Disable and remove lsass.exe Immediately. This process is most likely a virus or trojan.
Other processes are required for essential applications to work properly.
You can visit this liutilities.com and search for the process your not familiar with.
Please rate this if you find this helpful.
Thanks,
Mar 21, 2011 | Computers & Internet
Window can not find gphone.exe
gphone.exe is nowadays one of the most dangerous virus spreading very fastly.Its a trojan and changes your IE homepage and sends tries to open gtalk and yahoo messenger.It even sends messages to gtalk contacts.Its icon is just like that of folder icon and people thinking of folder click on it get infected by the virus.
Gphone virus basically is a 260 kb .exe file which looks like a folder and it can take any name of any other folder if you have clicked on the virus folder which looks like a folder but it isnt.If you have a folder name “comptalks” in your D drive it will make a exe file in the folder named comptalks.exe and if you click on that exe file it too work as a virus.It makes .exe files in all the folders you have with the name of the folder.
To remove the gphone.exe virus you just need to follow simple steps:
Go to Task Manager ->Processes and then click on gphone.exe and click on end process.
After that manually go to folder where gphone.exe is present and simply delete it.
Or simply search for the exe file clicking which started sending messages through gtalk. If you clicked on 1.exe search for that file on task manager and then delete it.
Good luck.
Sep 02, 2009 | Microsoft Windows XP Professional With...
Whenever i run regedit.exe ,after sometime window dissappears
Hello Friend,
Dont install two antiviruses it is not recommended
1.It slow downs the computer
2.There is a clash between two antiviruses .so they dont detect any viruses.
3.Try Kaspersky Antivirus or Kaspersky Internet Security..trial period 1 month
i think it helps.
if yes rate me
Jul 01, 2009 | Dell Latitude D600 Notebook
It ts not initializing
Hi there my name is Ibrahim Makki
you have to uninstall your macafee
Apr 15, 2009 | Computers & Internet
Slow in Booting and reading startup programs
go to Run, and type in msconfig. There you can shut off unneeded startup programs
Aug 04, 2008 | Microsoft Windows XP Professional With...
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
How to remove comm warrrior virus from nokia 3230.
You move on to some of phone repairer and ask him to remove virus and install an antivirus for it.
Sep 21, 2007 | Nokia 3230
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
225 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
