I have a 2000 jimmy and 2000 pontiac grand prix where the turn signal noise will come on without the signal being activated. it will stay on until the brake pedal is tapped.I have a 2000 jimmy and 2000 pontiac grand prix where the turn signal noise will come on without the signal being activated. it will stay on until the brake pedal is tapped.
AnonymousApr 22, 2009
The signal "clicker" keeps sounding when the signal is not on ...
You can't post conmments that contain an email address.
I don't recognise it but it could be a clicker or a warning buzzer. Lots of drivers like to hear the turn signal clicking when it is switched on but it wasn't always convenient to design them that way so manufacturers sometimes provided a clicker to provide the required noise.
You could try connecting it to 12 volts via a small fuse to see or hear what happens.
You most likely have a bad bulb, if the front bulb goes the rear wont work and vise versa both bulbs must be good to complete the cirrcut. Even though you have no lights you should still hear the flasher relay. Bulbs are cheap just replace both and you'll be good to go. Good luck
More than likely you've got a short in the turn signal switch. I have replaced a few of them.
It's easy to replace, but you need some specific tools and getting the airbag out takes some practice.
No the dash is the hazard light switch, it's also the turn signal flasher, dealer part only replace, replacing it will fix your problem. Feel the switch when you hear the clicking.
replace the turn signal 'Clicker' also known as the turn signal relay. Most likely the problem unless you have a really wierd electical issue that will be hard to isolate...
these vehicles have a very common problem that allows the flasher to click even though the signal is not on.. this is an internal directional switch problem and can either be taken apart and cleaned or replaced to correct the problem...
