Question about Kenmore 44042 Front Load Washer
I've only owned for 2 1/2 years. It was working fine then the next load I put in the machine would not work. No water comes in. I had taken the compartment that you put liquid detergent/bleach in to clean it and then it sounded like something dropped (not sure if related), however after that it was no longer working. I was told by a repairman that it was a computer board and I'm just wanting to know if that could be a possibility.
There is a little magnet in the detergent pull-out drawer.  I cleaned my compartment and had the same results.  After a lot of problem solving, looking at the schematic of the machine, calling Sears...I finally found a spot where the magnet might possible go - low-and-behold, I put it in and the machine works fine.  The magnet is located on the right-hand side of the compartment.
Posted on Mar 24, 2008
  • 641 Answers
It could be the computer board but in most of the cases the reason for your problem are: - A deffective lid switch - A blocked water-inlet line
Posted on Aug 22, 2007
My washer stops after washing. It won't drain or spin. What is the problem?
Whats your washer brand name. Is it top load or front load. The model number. It all depend on your machine model.
If it is KENMORE or Whirlpool top load more than 6 years old, then most likely it is your door switch. It is straight forward fix and cheap.
Sep 26, 2014 | Dryers
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Water goes into machine but woun't spin after about 5 minutes th 5 far right lights start to blink wait a minute hit start button everything works fine. kenmore front load 5 years old
This could be a few problems - from the timer to a pressure switch - to a bad lid switch.
Please reply with the exact model # for a more exact answer.
Mar 22, 2010 | Kenmore Washing Machines
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Hot water coming out on cold setting
try switching the hot and cold valves on the back of the machine and see if it works if it does just the oppiste then it's the water valve in the back where the hoses hooks up.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore front end loader HE 3t Model 110.45972400
Peace Friend,
ngfam1 At your service!
It is not an easy matter if you have never done this before!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Apr 14, 2008 | Kenmore 44042 Front Load Washer
Kenmore 44042 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
