Question about Bazooka ELA300.1 Car Audio Amplifier
Whats wrong?? i have 2 ELA300.1 and i cant either one of them to work. i dont know if my wiring might be wrong but it worked when i first up it in. i have it hooked up to 2 12" MTX. RMS is 225 and peak is 450 for the speakers. when i put the second one in the other day the power light came on but nothing came out of the speakers. now the light wont even come on. when i had the old one hooked up it work but quit after a few days. so i got a new amp thinking i might have blowin the amp but now i cant get the new one to work.
  • snoopygirl27 Aug 22, 2007
    i have checked everything..i get nothin. its the same with both amps. i checked my speakers. they r 4 ohms. i'm not sure if the speakers r to much for the amp maybe?
You should check the remote wire bc you will get power to your amps if its not hooked up but you wont get any music!
Posted on Mar 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi, You may want to check all the fuses. The amp power supply line might not be directly connected to the battery but passes thru the ign switch via a fuse, meaning it will only power up with the ign switch and the radio/head turned on. Another wire that you can check is the trigger on supplied by your radio/head unit. this is either blue or yellow color. Last that you can check are your speakers including the wiring. Make sure that bare wires are not touching any metal part of the car or the speaker themselves; finally, check your speakers, make sure that they are not open, shorted or grounded and that they really work. Better check by temporarily installing them in another setup or use a continuity tester which should show a reading of 4 - 8 ohms. Hope this gives you a few ideas. Post back how things are or should you need further information.
Posted on Aug 22, 2007
  • Louie  Role
    Louie Role Aug 22, 2007
    Hi again,
    missed asking, have you checked your grounding? Double check to make sure amp is properly grounded to the chassis of the vehicle.
  • Louie  Role
    Louie Role Aug 23, 2007
    Hi again,
    "ts the same with both amps" - then big chance there is nothing wrong with either of the amps. it's got to be the wiring;
    "i checked my speakers. they r 4 ohms" - did you use a continuity tester to verify if they're still 4 ohms?
    "i'm not sure if the speakers r to much for the amp maybe?" - two things here: 1. even if they were, the amps should still power on but then go to auto protect soon as it senses the speakers are "too much"; 2. as you posted initially, "but it worked when i first up it in." So it must be something that happened after the initial setup.
    There are 3 important wires to check, the big red which is always on or wired to the ign switch of the vehicle will measure 12VDC (use a VOM tester) or to the + terminal of your battery, the gnd or ground which should be body/chassis grounded or - terminal of your battery and the trigger which is a wire that comes from your radio/head unit which activates the amp also can be tested with a VOM. If your radio and/or ign is off there should be no 12VDC at this trigger wire but should have when the radio/ign is on, the big red wire should always have a 12VDC.
Compaq Laptop Windows 7 Acess Point Problem att 2wire
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Oct 29, 2017 | Compaq Computers & Internet
Heat and ac lever controls dont work
If the levers dont work then control may be bad but i would like so more info as to what is not working, for example is the fan blowing air and is the problem the temp cant be controlled or is it that you cant chage from vents to floor or defrost.let me know whats wrong.
Oct 23, 2011 | 1997 Buick LeSabre
My amp was working good and i didnt use like for two months and know it doesnt work the green light turns on but the red light too of over current and i cant hear nothing i dont know what is it..
if it turns red its a protection light you most likely got the ohms wired wrong on the speakers and the amp is going into protect mode so you dont fry it or the subs
Mar 04, 2011 | Sony XM-2150GSX Car Audio Amplifier
MTX 81000D amp doesnt work
Have you checked to make sure your sub is wired correctly to the amplifier?
May 30, 2010 | MTX Thunder 81000D Car Audio Amplifier
One is broken
Does it smell funny?Smell around the top of the magnet and see if it smells like burnt plastic.If it does then the voice coils are burnt.Push down in the center of the sub if it dont move at all or has a grind the the voice coils are burnt up.Look at the lead going from the wire hook ups to the speaker cone are the intact?If not thats your problem.
Jun 18, 2009 | Audiofonics ADF-272 Car Speaker
Smoked the ground wire going to the board
no one fix tghem as they are cheep and the parts are more costly including labor...
Microwave need ground I do not know how good you are in electric but you can make new ground for th unit it is easy if you know what you looking for...
May 25, 2009 | Cobra 2500w Power Inverter
Not sure whats wrong with my LANZAR MXA242 AMPLIFER. Please help!
did you check the fuses on the side of the amp? put voltage meter on b+ should read 13v, take it to service center to have checked out, may have some prblems inside
May 03, 2009 | Lanzar MXA242 Car Audio Amplifier
Cant get mp3 player working
How are you trying to get them to work? Are you trying to turn them on, play music, connect to the computer or what?
Aug 09, 2008 | Coby MP-C7085 MP3 Player
My screen is not working, but the phone itself works fine, i know whats wrong w/ it, but i need 2 know how to fixit!!!GRrRrR!!! it has 2 do w/ the copper wires that connect the screen 2 the motherboard!!!...
if you want to fix it you still have to buy a flex cable for nokia 5300 to any service center that has an available, the risk is if you fix it and didn't work and got damage you cant replace the item anymore.
Nov 30, 2007 | Nokia 5300 Grey Cellular Phone
Bazooka ELA300.1 Car Audio Amplifier Logo
119 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
