Question about Casio Exilim EX-S600 Digital Camera
Not taking photos?
I used my casio just yesterday to take two photos. I uploaded the entire memory to my computer last night and today the camera is fully charged, turns on, zooms...etc. The camera does everything except stores photos. It doesn't flash, just goes through the motion makes the 'gonna take a photo' noise but doesn't actually take it. The process just stops and when you check to look at the photo it says that "there are no files". The camera was not dropped or made wet. Could there be an issue with the upload? I've reset the simple camera options. Charged the camera, taken the memory card in and out as well as the battery. Thanks for your time.
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
See if you can display pictures in playback mode. If you can then it is probably the CCD sensor that is faulty ( either no image at all or heavily distorted pictures on you led screen in capture mode. camera should be repaired free of charge if it is the CCD block since properly manufactured one lasts 15 + years.
Posted on Sep 02, 2007
SOURCE:
Can't Upload Pictures
Try putting the memory card in a USB card reader attached to your computer, which should see it as another drive. Write-protect the card first.
Sep 16, 2017 | Fuji Finepix T410 Black 16mp Digital...
I put pictures on my sd card useing my camera but when i try to upload them to my computer it says that there are no new pictures to upload
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 26, 2013 | Casio Exilim EX-Z30 Digital Camera
How do i upload video from my nikon d7000 to my computer. Will upload photos but the video didn't
You neglected to specify how you're trying to upload your videos so I can only give general hints.
First, make sure you're using a program that recognizes videos. If you're using a program designed to copy photos, that's exactly what it will do -- copy photos. Videos aren't photos, and such a program will ignore them.
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or, as I suggested earlier, use a program that recognizes both photos and videos, such as Nikon Transfer.
Nov 25, 2012 | Nikon D7000 Digital Camera
I have a Canon A2000 IS, and up until yesterday I was uploading photos to my netbook without issue. However, when I've tried to upload photos today, everytime I connect the USB cable from the camera to the...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 17, 2011 | Canon Powershot A2000 IS Digital Camera
I have a Finepix z10 and am having a problem. Last night I was using it to take pictures and it was fine until it said memory full, which was a possibility but I was surprised. When I looked at it this...
http://www.fujifilmusa.com/support/ServiceSupportContact.do?prodcat=644675
This is a special problem and I would direct you to contact fujifilmusa.com directly about this problem with the memory card.
I'm not sure how to retrieve all of the photos that are missing that you took beyond the 60 photos that showed up.
Sep 02, 2010 | Fuji FinePix Z10fd Digital Camera
My camera won't turn on either....
Either the lens is out of alignment, or the CCD or worse has gone defective. Either way it sounds like it may be worth it to just purchase a new camera. You do always have the option of repair as well.
Thanks,
Lee
Jul 11, 2009 | Vivitar ViviCam 3935 Digital Camera
Hi i have a casio exilim and i am using a 2gb memory card in it, i went out last night and took lots of pictures after each pic was taken i viewed it to make sure it was ok or if i needed to take another...
You problem set your camera to use internal memory only. Set the memory function to memory card only and all pictures will go to the memory card until it is full. You can probably still transfer your pic files from internal memory to your card.
Nov 23, 2008 | Cameras
Memory card problem
Save yourself a lot of grief my friend...DON'T upload from the camera- it will usually hose -up. Get a cheap(5bucks or more) usb card reader. It is much faster, and so much more enjoyable. And you don't need special softwear to use it, It's plug and play. The computer just thinks the card reader is another drive. Much simpler.
Jul 26, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Computer can't see photos on memory card after removing to print at auto booth
This is common when you use a memory card that isn't recommended by casio. They only recommend using sandisk, toshiba, panasonic memory cards. Try one of those and you should have no problems.
Jun 11, 2006 | Casio QV-R40 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
85 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
