Question about Intel Motherboard
My Mother Board Does Not Detect My Hard Disk
My MSI Sockect 478 Mother Board Does not detect 160GB SLAta Hard Disk. I try in the Bios Setup also. What can do for it
    Brigadier General:
  • 6,966 Answers
Hi, I will assume that you are referring to the "Mother Board Does not detect 160GB SATA Hard Disk" when installing Windows. You need to press F6 when asked if you want to install other driver and follow on screen instructions. Good luck and post back how things are or should you need further information.
Posted on Aug 22, 2007
120G hard disk doesn't work on p4m266a mother board
The hard disk maybe faulty especially if the BIOS cannot detect the hard disk.
Try connecting the hard disk into an USB hard drive adapter and then plug it into the USB port of a working computer. If this computer cannot detect the USB hard drive adapter as an external storage device then this hard drive is faulty.
Oct 29, 2012 | Computers & Internet
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
Where can I find a driver for my hitachi travelstar IC25N080ATMR04-0
1. You shouldn't need a driver for the hard drive
the Bios ( Basic Input/output system ).
2. You mother board should detect the driver
3. You will have to go into the BIOS setup to see of your hard drive is detect then set the BIOS to boot from the hard drive
4. If your pc takes SATA ( Serial advance technology attachment) then a IDE ( Intelligent drive electronics) will not work with the system without an adapter.
5. Your PC mother board instruction manual will have instruction on hard to access your BIOS settings
Caution: Any changes in the BIOS will not allow some devices attached to your PC to work properly is not properly addressed in the BIOS setup.
Mar 19, 2010 | Computers & Internet
I tried to install SATA Hard Disc to MSI PT8 Neo-V Mother Board. But Even AMIBios Setup, it could not seen and when I try to install the windows, it tells no hard drive found.
cek our bios setup
1. is that addon card set to SATA or RAID?, SAT the set should be!
2. Broken? (maybe the cable not connect, power cable is bad or something else like, try to hear the sound working harddisk, teh sound because the HD's motor is working)
3. this time, the HD is very big enough, but the software not followed yet, so maybe your BIOS need to be upgrade, i dont know. try to flash it
at last, the HD only display detect when u boot the CPU. at BIOS is not display detect.
that my experience
sory if not helping
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
A6561SMS amibios v 1.7 on MSI 745 Ultra Motherboard does not detect the HD Seagate Barracuda 7200 Ide 160gb. The bios simply won't start. What could be? Are they compatible?
Dear user,
Yes HD is compatible on that motherboard but some problem in your ide of motherboard.
pl check your hard disk to another pc working or not ?
Ravindra Shah
May 17, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
Intel Motherboard Logo
132 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
