Question about Sony CDX-GT210 CD Player
Unable to connect to amplifier
Hi, and thanx a lot for this helpful site. I installed this cd player CDX-GT210 in my car and costed me around $180. Later, I was so disappointed coz I found out it can't be connected to amplifier because: 1- It has no RCA outputs 2- It has no "blue" slot to connect to the remote of amplifier Is there any way I can connect it to an amplifier ? Thanks
Thank you fellas! Now I got the speaker to rca device. Can I just use the cigarette lighter socket as a power source for the 12v? I bought an extention for the socket from walmart. The back of the amp has 3 inlets: 12v - Ground -Remote, which goes where? I am just scared of doing direct wiring to the battery. Thanks again :-)
Posted on Aug 24, 2007
    Novelist:
    Champion:
  • 218 Answers
There is commonly available a small device that will convert a small portion of the speaker level signal to an RCA level signal without having to open up your unit (I would not recomend that you open up your unit and start rewiring anything inside). Any place that installs car amps should be able to sell you such a device or try your local radio shack. It only costs about $10 or so and it will do just fine without loading down your speaker level outputs. As for the "trigger" switch, the simplest way is just like Benimur said, just attach a small switch that will supply +12 volts to the trigger wire when you want the amp to turn on. Good luck.
Posted on Aug 22, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Your post "Is there any way I can connect it to an amplifier?" yes, but that would require that you open your unit and attach a pair of shielded wire to the inputs of the built-in amplifier. Left, right and 2 X ground. The other end of the shielded wire can be terminated with a pair of RCA females. The "blue" slot can be replaced by a manually operated remote on/off switch. This however will void your warranty, probably it might be to your advantage to return the unit for a replacement model that has line outs. Good luck and kind regards. Post back should you need further information.
Wireing diagram sony cdx-gt210
Sony CDX-GT210 repair manual includes the wiring/connection diagram. If you want the copy, click here.
Jdvillanueva
Oct 11, 2011 | Sony CDX-GT210 CD Player
Can I get instructions for using CDX-GT210 2007 model
You can download and print the instruction manual for Sony CDX-GT210 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 04, 2011 | Sony CDX-GT210 CD Player
Just purchased a car for my daughter and it has a sony cdx gt210 player. No instructions, how many cd's can be loaded one or more?
Hi steve
To answer your question;
You can download the owners manual by clicking HERE
It has everything you need for info.
Hope this help
Cheers
Jun 03, 2010 | Sony CDX-GT210 CD Player
How to attach an amplifier with sony cdx gt210
You will need to have an amplifier that has speaker level inputs, or purchase a device that converts speaker level to line level. Here is a link to Sony for your CDX-GT210 wiring diagram. There are no rca outputs, only speaker outputs.
http://www.docs.sony.com/release/CDXGT210_Installation.pdf
And this link is for your operating instructions.
http://www.docs.sony.com/release/CDXGT210.pdf
Nov 15, 2009 | Sony CDX-GT210 CD Player
Had to have my battery jumped and since then I do not have power to my sony cdx gt210
pull the unit out of the dash if applicable and inspect the rear of the head unit(deck) there should be a mini fuse in the back of the unit or inline with your power supply to the deck sounds like you just blew a fuse
May 08, 2009 | Sony CDX-GT210 CD Player
Sony CDX-GT210 CD Player not working all of a sudden
remove the unit and the reset button should be a small pin hole on the back!
hope this helps
alex
Apr 06, 2009 | Sony CDX-GT210 CD Player
No signal on Radio,
Start with checking the antenna has an earth connection.
Dec 06, 2017 | Sony CDX-GT210 CD Player
I cant change the time?
Download User Manual of CDX-GT210 from Sony Support and go to Page-4 for clock setting detailed procedure.
Nov 10, 2008 | Sony CDX-GT210 CD Player
Installing Sony Explod CDX-GT210 CD deck
try connecting the red and yellow together, and to a 12 volt source. that should deffinately get power to the head unit.
check the fuse under the big connector on the back.
Sep 24, 2007 | Sony CDX-GT210 CD Player
Sony CDX-GT210 CD Player Logo
90 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
