Question about Bosch WFMC 3200 Front Load Washer
Ticking/chirping sound during slow spin
My washer is about 3 years old and gets heavy use (family of 5, including 3 small boys wearing cloth diapers...not all at once mind you, but sequentially). In the past month a noise has started during the wash cycles. It can best be described as a ticking or chirping sound at ~1 second intervals when the washer is in slow spin, or agitation mode. The noise stops during the fast spin out. The noise does not occur at all if I manually rotate the tub when it is not washing or if I run the washer without anything in it. Washing performance does not seem to be affected, but the noise is annoying and I am nervous that it indicates a more significant problem developing. Any help, advice, suggestions are greatly appreciated!
    Novelist:
    Champion:
  • 244 Answers
It will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Posted on Aug 23, 2007
Problem during wash cycle
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Mar 19, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
Washer has squealing sound and burning rubber odor
Yes, its basically in need of a overhaul, which the parts involved, basket drive/clutch and gearcase are all wearing out, I've seen this happen many times and cause the squeal/spin cycle and then in time to slow then stop spinning altogether.
From the parts diagram it said this model was made in 1998. The only time I have changed these parts on a model this old is when the customer purchased a service contract when it was new and kept paying on the contact year after year, thus the repair was free to them, but most of the time its NOT practical to keep paying on a service contact for up to 10 years unless you have heavy/extreme, daily/many times of day use of the washer, usually for large families living in the same household.
Here's the list of parts I always change for this issue, now some members and techs. could possibly change just the basket drive/clutch assembly or just the clutch alone and it may work for another 6 months or year and a half, but I found when I used to change the parts separately I had to go back to change the other parts within 6-18 months.
Oct 14, 2012 | Frigidaire GLWS1349A Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Kenmore top loading washing machine drains but does not spin
Sounds like the coupler broke. This connects the motor to the trans. The part is only like 25.00 and labor is about 140. When it tries to spin if the basket doesn't move at all, then this is it. If the basket is really slow or easily stopped with your hands then the clutch/trans. could be bad. More times than not, it's just the coupler. These are made to break under heavy load, so it doesn't hurt anything else. They are just rubber and plastic and sometimes break for no reason. Push the lid switch with a pen or something with the lid up and try to spin to see what happens.
Mar 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Alll the water does not spin out , clothes still wet
Your clutch is wearing out and needs to be replaced. It will only get worse. Ive included a schematic , part # is 285785. #5 on the schematic. Let me know if you need more help, thanks dave www.washermd.com
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Bosch WFMC 3200 Front Load Washer Logo
437 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
