Question about Dell A215 Computer Speakers
Speakers make a buzzing noise but wont play anything else
My speakers are plugged in where their suppose to be but when i went to use them all they did was buzzed..and no matter what i do with them they continue to buzz what should i do?
  • lennonhead71 Dec 08, 2008
    my speakers arent working at all. only when i try messing with the connection will the make a buzzing noise. they have worked in the past i need some help here! :o(
    Problem Solver:
  • 10 Answers
Make sure that your system volume is turned up and that the speakers are turned all the way to the right.
Posted on Aug 23, 2007
SOURCE:
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
My speakers are currently turned on, at normal volume. Whether I try to play music or not, a buzzing noise comes from the speakers.
your power supply is bad for the speakers giving them to much power or there bad speakers plug some headphones up and see if it makes the buzzing if it does then you have a power problem with your computer or sound card
Mar 17, 2010 | Audio Players & Recorders
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Static noise panasonic home theater
Simply unplug the machine for more than one minute. Then plug it back in again. That makes the system reset and the problem went away.
Sep 03, 2009 | Panasonic SC-HT700 System
My Speakers On My Computer Wont Work But I Can Hear A Buzz Sound?
1st of all click on start->programs-> Accessories->Entertainment->Volume control->options->properties->select Microphone->then click on Mute on microphone. hope this will work
Jun 07, 2009 | Computers & Internet
My speakers are not plugged into any soundcard but are buzzing
May be a short somewhere, speakers always have a little white noise and buzzing, usually nothing you'll notice.
May 28, 2009 | AOpen MA-691 Computer Speakers
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Buzzing noise when played on big stereo from cable?
you need a loop bypass filter. you can buy them at walmart for 10-15$
Apr 30, 2009 | Car Audio & Video
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Loud buzzing noise
Bad connections or faulty wires check the wires and the connection of the wires, usually the buzz is a bad earth
Nov 16, 2007 | Acoustic A-5640 Computer Speakers
Dell A215 Computer Speakers Logo
456 people viewed this question
Top Dell Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Steve Mason
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
