Question about Tomtom GO 700 GPS Receiver
Charging but nothing on screen
I used my Tomtom on Sunday for a long trip. I used it briefly tonight before realizing that it needed a charge badly. The unit went dead, so on the way back, I plugged it into my car. The little green light comes on, but the screen stays black. I am now at home and have it plugged into it's regular charger and the same thing is happening. I'm not aware of anything happening to the unit after I used it tonight. Can you offer any help?
  • Anonymous Sep 01, 2008
    Vores tom tom 700 er også umulig at tænde,vi har ikke brugt den i ca.enmåned og da vi så ville bruge den vil den ikke tænde ,jeg har forsøgt med både netladeren og bilen,men den vil ikke ,der er kun lys i den lille grønne lampe,og kun når den er sat til en strømkilde,det virker som om batteriet ikke kan holde strømmen.Jeg har set nogle af jer andres problemer og flere skriver at man skal nulstille gps,en hvor er den nulstillingsknap i skriver om
    venligst Erik
    Problem Solver:
  • 6 Answers
A good place to start is a reset. -Make sure the battery is charged completely (charge for two hours to be sure) -remove the SD card, if you use one -hold down the reset button with a pen for at least 15 seconds -release the reset button and hold down the on/off button for at least 5 seconds. -replace the SD card If that doesnt work: Make sure you have the latest software for the device by using TomTom Home. Sometimes just updating the software will kick it into gear, so to speak. And lastly, if it is just dead, contact TomTom customer care and they will repair or replace it for you. Before you call them make sure you have a TomTom account. To register:https://www.tomtom.com/myTomTom/myProfile/ Hope this helps!
Posted on Aug 24, 2007
So my bike was riding fine up to Thursday night. I just changed the oil on Sunday and every time I rode it there were no issues except for the bike taking a while to turn over about half way through a 4...
As I'm sure you suspect, changing the oil and sparkplugs should have nothing to do with the symptoms you've outlined. The symptoms "seem" to indicate a problem in the charging system. Either the battery is in need of replacement or the regulator is fried. One way to test which is at fault is to jump start the bike (be VERY careful doing this as a car battery will fry your system if you connect it wrong). Once it is started, remove the jumper cables. If you need to rev the engine slightly to keep it running, this is normal as a dead battery is a big draw on the electrical charging system. If you can, have a friend hold the bike RPM's around 1500 and disconnect one of the battery leads on the bike's battery. If the bike continues to run (my suspicion is it will), you have a bad battery. If the bike will not run, then the charging system is the culprit. It could be something as simple as a regulator or as complicated as the generator (inside the engine).
Apr 10, 2011 | 2005 kawasaki ZZR 250
My Tom tom will not turn on, it is charged the green light comes on but nothing on the screen I have used it only twice
you have blown one or two charging chips inside the tomtom through a faulty charging cable, it will need to be professionally repaired as the chips are very,very tiny and are hard to solder
Mar 12, 2011 | Tomtom GPS
Charging tomtom
try soft reset before thinking of having killed it. do the reset while it is charging normally its charging while conn. by usb. good luck
Feb 12, 2010 | GPS
How do I tell if my Tom Tom is charging on the computer. While on the computer charging I am unable to use the touch screen to see if battery is charging or full. How long should it take to charge on...
Plug the USB terminal into a port and when the unit asks you if you want to connect to the computer tap No. If your screen displays a status bar, tap in the middle of the bar and you will see a map of the last trip. The battery gage will appear on the top right corner, along with the satellites.
If you do not have an old itinerary stored, plan one in the neigbourhood so as to make the status bar appear and tap in the middle of it.
Jan 02, 2010 | Tomtom ONE GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tomtom One screen problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom ONE GPS Receiver
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 700 GPS Receiver Logo
126 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
