Question about Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range
Five Star Dual Fuel Range Issue
Just installed.... gas oven and gas griddle lite first time, but will not start now. They use the 'glow bar' ignition system.
  • wzl1234 Aug 27, 2007
    Thanks... It actually appears that the glow bar ignition has broken (cracked)... also, now the electrical oven will get warm but not hot.
  • 640 Answers
Make sure the gas pressure is correct.get a small torch and heat up the flame switch (it sits above the glow bar)and see if the burner lights.
Posted on Aug 26, 2007
SOURCE:
Whirlpool range glow bar glows but no gas for flame mod sf315pekq1 ser vep1506815
iHello,
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
The part number for that igniter is 98005652 it could be purchased from your local appliance parts store or online at;
repairclinic.com
apdepot.com
searspartsdirect.com
apwagner.com
midwestapplianceparts.com
Gene
Aug 22, 2011 | Whirlpool SF315 Dual Fuel (Electric and...
Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
Our glow bar lights up when gas oven is turned on, then the gas comes out, but it takes a long time to lite the gas resulting in an explosion inside the oven. Or with too much gas filling up the kitchen....
Typically the issue here is a weak glow bar (hot surface ignitor). When they weaken they open the gas valve slowly and it takes a bit for the ignitor to light up the oven burner.
It is a safe bet that you need to replace it.
Apr 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
OVEN WILL NOT (GAS) LITE
With the assumption you have a gas range with electric ignition and is fully powered (plugged in); the possible problem may be the "Electric ignitor/Glow bar".
When turning on the oven, do you see a redish (good) or yellowish (not good; replace) glow emitting from the very bottom or the oven/broil area?
There are typically 2 types of electric glow bar ignitors; Round and Square. Ignitors are actually fairly easy to replace, removing 2 mounting screws and cutting/splicing 2 seperate wires together. Is your ignitor "round" (circular - like size of finger ) or "square" (rectangular - like snickers candy bar)
If your ignitor is not coming on at all; this can be a couple things;
Defective Ignitor - Gone completely Bad - Out (Assuming your have full power 110v to ignitor)
Defective Gas Valve - Assist in passing 110V to Ignitor
Defective Control Board / Thermostat: Assist in passing 110V to Ignitor
FYI - As a safety measure, the ignitor needs to "come on and appear solid red" to properly pass power to gas valve; thus opening and allowing gas to pass through the burners and combust.
Jan 27, 2009 | Magic Chef 31203 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Sep 06, 2008 | Viking 48" 6 Burner, Grill Professional...
Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range Logo
568 people viewed this question
Top Five Star Kitchen Ranges Experts
Steve Allison
Steve Allison
ray gallant
ray gallant
Tom Chichester
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
