Question about Zebex 90940-RS232-9 Handheld
No code appear after I scanned the barcode.. Please help!
I attached my Zebex Barcode scanner on my PC by connecting in the keyboard port... It was detected by the PC but everytime I scanned barcodes, no value was received by my application from the scanned barcode. Please help me do this... here is my email... [email protected]! Im from the Philippines, Im male and a intermediate VB6 programmer. Hope somebody could help me.
  • mcxiand Dec 16, 2008
    i have the same problem
    Problem Solver:
  • 20 Answers
First of all,have you tried using a notepad ? just to verify that your scanner connected correctly to your pc If it's fine then you should find out if there's an enabled properties of your object such as text box, combo box, that was set to False,change it into true.
Posted on Aug 24, 2007
SOURCE:
I HAVE 5 SCANNERS, FOUR OF THEM SCAN AS THE ITEMS PASSES IN FORNT OF THEM AND THE FIFTH ONE NEEDS TO PRESS THE BUTTON. HOW DO I CHANGE THE FIFTH TO SCAN AUTOMATICALLY
If you look in the manual, you will see the code to place the scanner in to "stand" mode which should do as you request. This mode is restricted to certain models however. Near as I can tell, there are a few variants of the Z-3051HS model that support this. Reference the manual at the link below. Please update this with any other questions you may have.
Thanks,
Dan
Link: http://www.zebex.com.tw/old_website/documents/users_manual/handheld/z_3051hs.pdf
Apr 02, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
Scan a barcode and the help menu of the program. LS4000i
Disconnect the scanner from the mouse port or disconnect the mouse from the scanner. The scanner must be connected to the keyboard port and have a keyboard attached to the scanner.
Aug 05, 2009 | Symbol LS 4000i Handheld
My scanner scans different numbers to what is on
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Mar 07, 2009 | Zebex ZB 2200AM
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
How can I determine input whether coming from keyboard or scanner?
Why you need to know from which it is comming? As a wedge is 2 inputs is merged as 1 output. There is no way to tell unless you use special coding in the BArcode that cannot be manually keyin. If I know your need maybe there is a altermnate way to do it.
Apr 03, 2008 | Zebex 90940-RS232-9 Handheld
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
Zebex 90940-RS232-9 Handheld Logo
254 people viewed this question
Top Zebex Computers & Internet Experts
Ekse
Alun Cox
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
